Braking problems
imported_alecblack Jun 22, 2005
  1. Hi All,
    Can someone help me out here?
    I am getting vibration through my steering wheel when I am braking but this is only happening when my speed is hitting 50-60mph when i am below or even above that the problem does not exist. I thought it may be my tracking but kwik fit assured me this was not the case. my back brakes (discs & pads) were replaced 3 months ago and the mechanic assured me then that my front brakes were ok and still servicable.
    Any suggestions/anyone had this problem before?
  2. paul_brad
    paul_brad Member
    365
    It sounds to me like the front discs are warped.
    Although there wouldnt be any vibration at slow speeds, can you feel the discs touching on and off? (It helps when there is rust on them to hear the scrape a little better!)
  3. speedyp
    speedyp Member
    123
    What are your tyres like???
    I had a slight vibration when coming off the throttle around 50 - 70 mph, shortly before replacing the front tyre!
    After a new set of boots, no vibration!! They had worn a lot more on the inner side of the tyre, which could have been the cause!!
  4. Both of your explanations sound valid.
    kwik fit said to me that the discs were warped without looking at them but i always get a second opinion as they cannot be trusted. My tyres are slighlty more worn on the inside and outside edges, so this could also be the problem.
    cheers guys
  5. Pontio
    Pontio Member
    209
    Even though the brakes are serviceable they could still be warped.
  6. clarko
    clarko Member
    also to throw an another option, you could have lost a wheel weight thus throwing the wheel balance, happened to me once before. worth checking this before spending money on brakes at kwik sh!ts say so.
  7. peteA3tdi
    peteA3tdi Member
    408
    if the discs are warped then you should still get the vibration over 60mph , take the car to a MOT station and get them to check on the brake rollers as this will show if they are warped or not, it maybe the lower arm bushes
  8. Got my car serviced yesterday and it turns out the problem was my discs rusting on the outside edge. This was a relief as it only cost £30 to skim the discs and it has now sorted the problem.
    cheers guys
