  1. r3stu
    r3stu Member
    111
    Going to change all my discs and pads. Am i best sticking to genuine audi ones or is there any better makes out there? Also after low dust pads???
  2. navnayyar
    navnayyar Member
    756
    im using EBC yellowstuff pad and doing a good job at the moment, brake dust is less than oem aswell. Im still using oem discs but soon as they've had enough Il be getting some EBC ones.
  3. Brett Butler
    Brett Butler Member
    664
    13
    I am thinking of upgrading pads, Personally do not think the OEM brakes on my S3 are that great. Are the EBC Yellowstuff quite an upgrade over the OEM, are they a good compromise for wear, dust, and stopping ability over OEM?
  4. BigBird
    BigBird Lost in music...
    382
    I recently had new OEM pads, discs and brake fluid done at the same time. I was perfectly happy with the OEM set up, as they worked very well before, but this set don't work so well, even after 1,500 miles to bed them in. They've lost the progressive modulation I had before.
    Kind of wish I'd gone for some other pads. Most seem to like the Ferodo DS2500, with both good and bad written about EBC pads. Do a search Stu to find out the threads on this...
  5. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    If you want good performance pads i like most people run Ferodo 2500 which are excellent but not the cheapest pads about.
  6. Pii
    Pii Member
    748
    Would going for these result in faster wear?
  7. devonmikeyboy
    1,245
    No the ferodo`s last a long time. It all comes down to how you drive your car really. The ferodo 2500 are very good performance but cost more then standard pads. If you just drive the car from A-B around town etc Ferodo 2000 pads are good or just use any pads from brand name companies. I personally would only use EBC pads as a paper weight as they are cheap for a reason.
  8. r3stu
    r3stu Member
    111
    I have a 1.9 tdi, Been offered a new set off 2.0tdi calipers,discs,pads. Does anyone know if this is a straight forward swap over? Cheers
  9. S3Alex
    10,769
    4,791
    I'd have to agree completely.
  10. Brett Butler
    Brett Butler Member
    664
    13
    Am I right in thinking that the ferodo brakes have no lead to connect to the low pad warning light?
  11. davej_anderson
    davej_anderson Member
    261
    Correct, and technically the 2500s aren't road legal......
  12. S3Alex
    10,769
    4,791
    Out of interest...why are they technically not road legal?
  13. Brett Butler
    Brett Butler Member
    664
    13
    Ok let me ask question again :) Are there any brake pads out there that are road legal, do have the leads etc. direct swap for OEM ones that are better than the OEM ones?
    Thnka
  14. davej_anderson
    261
    A european standard (R90 I think) says that the component should work within +/-15% of the original equipment. The DS2500 exceeds +15% hence why most online places list these pads as track specific or track only
  15. devonmikeyboy
    1,245
    Ferodo DS2500 are more then 15% better then standard then it`s a fact. Nobody is ever going to get prosecuted for having DS2500 pads on their car in England so don`t let worry about that. Most after market pads do not come with leads attached to the pads. All you need to do is join the two leads together that come out of the back of the plug from an old set of pads and plug it into the car as you usually would and you will get no brake pad warning light.
  16. S3Alex
    10,769
    4,791
    FWIW Dave,I'd rather have a car fitted with brakes and pads that were at least 15% better than standard if not a great deal more.
    I had Ferodo and Pagid pads on previous cars,and never had any legal matters quoted.
  17. davej_anderson
    261
    Don't get me wrong, the DS2500 pad is universally rated as being an excellent fast road pad - I only found out the R90 point as I was going to fit them myself - but I thought that people should be aware of this, although as you say I'm sure no-one is ever going to get prosecuted by using them
  18. micasb
    micasb Member
    327
    Hi.
    No. You'll have to change the intire wheel system...
    Regards.
  19. r3stu
    r3stu Member
    111
    What does the entire wheel system include? Cheers
