  1. chris1988brown
    chris1988brown Member
    575
    hi guys, quick question, what are the sizes of the front and rear discs on a 07 2.0tdi 170 s-line and what size are they on a s3? also is it worth upgrading to the s3 brakes as ive been offered a full set for a cracking price?
    cheers in advance chris
  2. EvolutionV
    EvolutionV Member
    203
    S3 brakes are a big upgrade against stock, i'd upgrade if i got a set for cheap...
    front discs are 345mm
    rear discs 310mm
  3. N8
    17,163
    718
    S3 brakes are VERY good, especially as an upgrade to a TDI, so get them!
  4. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    standards are arond 288mm and i done the upgrade in the past and it was definitly worth it.
    The standard brakes with a remap and me at the wheel didnt feel up to i but the S3 stuff was the business.
    S3/LCR (Newer one)/3.2 A3/R32 - Same brakes, diff looks.
  5. chris1988brown
    575
    cheers for all the input guys:) is it just a staight swap with the originals, all the brake lines just swap straight overs etc? ]
    cheers chris
  6. N8
    17,163
    718
    I agree, but I'd say imo, the standard brakes didn't feel upto it with standard power with me at the wheel :laugh:
  7. EvolutionV
    EvolutionV Member
    203
    Yeah a straight swap but you will need a set of s3 brake hoses/lines coming off the caliper as they're different
  8. Scott
    Scott Well-Known Member
    1,306
    126
    Anyone know how much I should be paying "all in" for a set of S3 brakes front and rear? And what about fitting?
  9. N8
    17,163
    718
    pm Kaz, he's got a set for sale Scott.
  10. chris1988brown
    575
    cheers again, i think i'll get a full set of braided lines to go with them:)
  11. N8
    17,163
    718
    Sounds good Chris.
  12. Scott
    1,306
    126
    Cheers Nath
  13. N8
    17,163
    718
    Its ok, my young brother.
  14. davej_anderson
    davej_anderson Member
    261
    To install the brakes do you need to bleed the brakes following doing all the nuts and bolts up and is this an easy job?
  15. EvolutionV
    EvolutionV Member
    203
    You will definately need to bleed all 4 calipers, not a hard job i would say but requires 2 people. 30 min job max
  16. davej_anderson
    261
    May just try some Ferodo DS2500 pads instead for now
