  1. toaophil
    toaophil Audi!
    69
    Hi all,
    I have a noise ..... and its gradually becoming louder.
    You can mainly hear it with windows down, especially when driving alongside a wall/hedge
    Sounds like mainly the front - I think. Possibly both sides.
    The best way to describe the sound is, its like the brakes are slightly on, and the discs are buckled, causing a metal on metal rubbing sound that 'wurrs'
    Brakes and discs appear visually ok.
    And - when I brake - It doesnt get louder, nor can I feel anything odd.
    Baffled!
    Any help appreciated.
    Phil
    A4 Avant 1.8T
  2. Mike.M
    Mike.M Well-Known Member
    2,507
    169
    May have a stone between disc and pad. Take the pads off.......clean and re grease before putting back together. This will also give you a chance to check the inside pad in case you have sticking caliper that has worn the pad out meaning there is metal on metal that can also give a grinding effect
  3. hades-
    9,481
    646
    as above
    first thing is to strip down check alls ok and no grit stones trapped.
  4. SuperV8
    SuperV8 Member
    70
    12
    Would you say its more of a squeal? or a graunch? High speed? or low speed?
    Is it constant when braking or does it sound like it could come and go each wheel revolution?
    Do you also get and judder when braking or is it just the noise?
    You really need to take the calliper off and have a look, check nothing is sticking/seized.
    Pads should be free to move in the caliper carrier, carrier sliders should be free and slide smoothly, and pistons should be free and push back into the caliper easily with the piston wind back tool. If one pad is thinner than the other it's a sign something isn't sliding properly.
    This needs to be checked for each suspect corner.
    If some part of the brake system is sticking/seized it will mean the pads can't release properly and can overheat/glaze which can cause noise.
    What pads are they? Should have an anti-noise shim on the back.
    Also if the discs are mounted on a hub that isn't perfectly clean they will 'run-out' so with every wheel revolution the pads will wear one spot on the disc. This part of the disc will wear thin and cause judder possibly noise.
    Were the pads properly bedded in? avoiding heavy/high speed braking in the first few hundred miles? If not this can also cause the pads to be noisy.
    Tom.
  5. toaophil
    toaophil Audi!
    69
    like a smooth grind sound with the turn of the wheels. Has a louder point on each revolution. Mainly noticeable at low speeds. No louder when braking. Brakes work well. No judder.
    hoping it wont be linked to a driveshaft/hub/bearing problem!
  6. Mike_B
    Mike_B Active Member
    533
    47
    As above - if it's still present while braking though, I'd be inclined to suspect a bearing.
