  1. millsyd
    millsyd Member
    114
    does any one know if the brembo calipers for the leon cupra r will fit on an audi s3.
  2. JamS3
    JamS3 Active Member
    2,258
    23
    Yes they do!
    I'm doing this mod as we speak, you will also need the caliper carriers from the calipers and 323mm x 28mm discs.
    Also if you have the 18in rs tt wheels then you will need wheel spacers or your alloys will rub against the caliper which I found out!!
  3. millsyd
    millsyd Member
    114
    i knew the standard leon cupra r had the same size disc on as the s3 but wernt shaw if the brembro kit run bigger disc or not. where did you get your parts from a scrap yard or from seat them selfs. how much do you think it will cost all together? thanks dave
  4. JamS3
    JamS3 Active Member
    2,258
    23
    The standard S3 has smaller discs than the cupra r!
    Standard S3 - 315mm x 25mm
    Cupra R - 323mm x 28mm
    I priced all the parts up at a local Seat dealer first as I was going to go this route but even with discount the price was well over the price of a new Brembo GT kit (£900+)
    I managed to find a full Cupra R kit from a local VAG breaker specialist inc discs (only 200miles on them), pads, calipers and caliper carriers.
    The calipers were quite scratched from the accident/laying around in the workshop but are in full working order and virtually brand new.....bargain for £400 cheaper than a main dealer!
    Just touched the scratches up with a paint stick colour matched from Halfords.
  5. madvr6
    madvr6 New Member
    9
    Sounds good mate! get some pics up!!!
  6. JamS3
    JamS3 Active Member
    2,258
    23
    Will do, getting them fitted this Sat morn...
  7. millsyd
    millsyd Member
    114
    could you give me the breakers number up by you please.
  8. benjy
    benjy New Member
    wot size spacers do you need?
  9. JamS3
    JamS3 Active Member
    2,258
    23
    I put 5mm on the front and this leaves them very close to the calipers but they look good!
    Will be getting some 10mm ones for the rear soon to match them up
