brakes -sharpness- compared to golf tdi mk5
vw754 Jan 4, 2012
  1. vw754
    vw754 vorsprung Durch Technik
    2,329
    58
    Hi, i own a A3 tdi and have replaced all 4 discs and pads for genuine ones........the brakes are 100% brilliant as before......one thing ive never figured out is,theyve never been sharp as the golf mk5 my other half owns.
    the golfs brake pedal only need to be touched and the brakes are well sharp........just like a brand new car......where as my audi ones are good but never been as sharp........any ideas? i would of thort new discs/pads would of made them like new again.
    The golfs pedal must travel about 2 inches and the audis must travel about 3-4 inches before the car brakes
    Maybe theyre just different?
  2. 1inchpunch
    1inchpunch Member
    451
    Probably different on every car. I'd actually say the brakes on my A3 are a bit too abrupt. There's is little modulation so they are either on or off which means you need to be really gentle to avoid putting passengers through the windscreen.
  3. vw754
    2,329
    58
    maybe a brake fluid change/bleeding cud make a difference??????
  4. 1inchpunch
    1inchpunch Member
    451
    Had the fluid changed last month and no difference. Don't get me wrong, I'd rather the brakes were like this than the unresponsive **** that was on my BMW. Sometimes you'd hit the pedal and nothing at all would happen.
  5. marknjayne
    marknjayne Member
    425
    mine too,well over servo'd
  6. Khufu
    Khufu Well-Known Member
    5,704
    31
    mine aren't harsh, unlike my mums clio!
  7. cloughy
    cloughy Member
    515
    I'd say my A3 brakes are better than my Golf, as mentioned above get the fluid changed IMO
  8. N8
    17,163
    718
    The standard TDI brakes are AWFUL imo.
  9. loudchris53
    loudchris53 Member
    402
    My brakes are very sharp at the top of the pedal but you have to push quite far down to get any more braking power, quite hard to be smooth
    Chris
  10. Khufu
    5,704
    31
    I'd prefer your chosen system lol
  11. N8
    17,163
    718
    But seriously, before I was mapped, I thought they were atrocious then!
  12. Khufu
    5,704
    31
    mmm, I could do with a remap myself, does it hurt? :p
  13. c_w
    c_w Well-Known Member
    1,163
    87
    Mine have a dead spot for an inch or so and then come on very strong. It feels like the fluid could do with a bleed but even after doing this it still has the dead spot. This is a 170TDI with the bigger 308(?)mm setup.
  14. N8
    17,163
    718
    Your brain needs a map
  15. Khufu
    5,704
    31
    not just brain, whole body LOL
  16. snoopi
    snoopi New Member
    15
    I was thinking the same when I got my audi, they dont seem to be very sharp..
  17. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    569
    149
    43
    Ditto very disappointed with mine. The V50 I had before had awesome standard brakes.
  18. Khufu
    5,704
    31
    I was bidding on S3 front ones last night but fell asleep before it finished LOL
  19. XXXCorps
    XXXCorps Member
    194
    27
    I've always thought this to be the case; I've had 2 MkV Golfs, an Audi A1, an 8p2 and 2 8p3 A3's and the brakes have never felt as sharp as the VW. However, my current A3's brakes are s##t hot so it could just be that I've gotten used to them...
  20. 1inchpunch
    1inchpunch Member
    451
    Awful in what way?
    Mine are snatchy but probably the best standard brakes I've had on a car in terms of stopping the car quickly, they just take a bit of getting used to prevent every stop form being an emergency one. It's scary when I drive other cars because I'm now so gentle with the brake that I often have that "oh sh*t" moment where I think the brakes don't work at all.
