Brakes causing vacuum/boost issues.........
Dani_B19 Feb 27, 2012
  1. Dani_B19
    9,253
    377
    Right.
    Pulled up from work today, parked the car up the drive and let it idle for a minute or 2, but for some reason i pressed the brake to which i noticed the boost gauge move.
    The car idles bang on 20 inhg without any movement on idle now but, when i started to press the brakes, the vacuum was creeping up to 17/18 inhg, if i kept pressing the brake the needle would just keep flicking up and down between 20 and 17 inhg.
    Now to me this isn't normal and shouldn't happen, it should sit bang on 20 inhg regardless of the brakes!
    I do remember Andrew having to replace the brake pipe behind the heat shielding next to the bulk head, cant remember what the proper name for it is, could this be at fault?
  2. jay1601
    jay1601 Well-Known Member
    1,338
    70
    its normal. the brake booster runs off the vacuum system (normally pipe coming off the intake manfiold)
  3. Dani_B19
    9,253
    377
    So does yours do this jay?
  4. jay1601
    1,338
    70
    mine will go between 18-21depending on throttle load, gear, braking, ect.
  5. Dani_B19
    9,253
    377
    What on idle? Surely if the cars sat idling then the idle shouldn't move.
  6. jay1601
    1,338
    70
    when on idle (no brakes or clutch/gears) will sit bang on 20
  7. Dani_B19
    9,253
    377
    yeah thats what i mean mate. I was sat on the drive earlier in neutral and then the above as post 1# started happening which to me doesnt seem right.
  8. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    Mine never sits bang on 20? Always about 16inhg. What would this indicate. Also it fluctuates when steering wheel is moved, even at idle :s
  9. Dani_B19
    9,253
    377
    MAY JUST BE YOUR GAUGE MATE, BUT YOU WANT IT TO SIT AROUND 18 TO 20 INHG, IF LOWER THEN NORMALY MEANS A VACUUM LEAK ETC.
    MINE DOESNT DO THAT WITH THE STEERING WHEEL.
  10. Dani_B19
    9,253
    377
    So anyone else any thoughts?
  11. Alais DJA
    Alais DJA Member
    559
    50
    Turn on your heaters
    Open your electirc windows
    Turn on full beams....... it always drops a tad
  12. Westy
    Westy Well-Known Member
    17,443
    1,103
    Nothing to worry about mine is exactly the same.
  13. S3featesV9
    1,032
    12
    Yeah. All good and bill said it should fluctuate when steering wheel is moved as it putting load on the engine.
    One less thing to worry about
  14. Dani_B19
    9,253
    377
    Thanks lads.
