brakes again !
murdoch Apr 27, 2011
  1. murdoch
    murdoch Member
    44
    i have managed to get myself a little confused ( quite easily done ), i need a new set of pads and discs for the front of my tdi avant, it's obvious i have vented discs, but i'm unsure what pads i need.yes they do have springs in the calipers, but i don't know if they have wear indicators or not. is it easy enough to see without taking the wheel off?
  2. aragorn
    18,485
    855
    If your worried you can always just buy the ones with the wear indicators and cut the wires off if they arent needed.
    Probably best just popping the wheel off and having a look though. That way you have an idea in your mind of how the pad looks so you can be sure you've baught the right one.
