Brake wear indicator cable
owdgit Jul 18, 2010
  1. owdgit
    owdgit Member
    126
    Hi, was wondering if this is a reasonably cheap part.
    It is the cable from the brake and anti lock at the hub end that goes into the bulkhead, it has a red and a black connector inside the bulk head after passing trough a grommet 2 cables to each plug.
    Would need both sides as the brake wear indicator cable has broke at the join to the connector block at the hub end.
    Audi A6 2.5tdi 2001 tiptronic.
    If it is silly money I will probably replace it with new cable and spade terminals.
    Thanks.
    Chris
  2. stoke_audi
    stoke_audi Active Member
    2,243
    19
    hi
    the wiring comes with the ABS sensor
    £131.50 inc vat
    Dave
  3. owdgit
    owdgit Member
    126
    Cheers Dave, the soldering iron it is then, its only the brake wear indicator that the cable has worn.
