Brake warning symbol
itsmeagain Oct 18, 2011
  1. itsmeagain
    itsmeagain 1.8T Sport Cabriolet
    434
    When I start my car I sometimes get the brake warning symbol light up on the dash. And it makes a warning sound for a few seconds. Then it's ok. But yesterday I got into a boy racer moment on a roundabout with a Seat leon Cupar r, and the brake warning light came on again. Any ideas what it could be?
  2. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    Warn pads
  3. kite
    kite Member VCDS Map User
    677
    brake warning on first start up is a sign of a dying battery
  4. olly quattro
    olly quattro Member
    78
    or brake fluid low caused by worn pads,,,
  5. niftyandy
    niftyandy Member
    100
    fill the fuid bottle up to the brim...going quickly round roundabouts with low fluid level will expose the sensor in the bottle and cause the red brake light to go on in the dash!!!
  6. swarcup
    swarcup Well-Known Member
    1,326
    40
    im with kite, it usually the sign of a dying battery. If the symbol stays on then investigate the fluids. I would pop and get your battery checked first
  7. itsmeagain
    434
    Battery is just over a year old. Will check the levels of the fluid when I get a chance today
  8. marktdisport
    marktdisport Active Member
    1,195
    15
    Have you checked the front pads, just to clarify the pads are ok aswell......
  9. hades-
    9,481
    646
    fluid pads
    and have batt checket age dont realy matter they can go in a mth
  10. marktdisport
    1,195
    15
    especially if the car isnt in daily use...
  11. Stubie
    Stubie Member
    135
    Mine came on , just topped up the fluid and touch wood hasn't come on since !!
  12. marktdisport
    1,195
    15
    I have jump started my mr's sisters chaps 2003 a4 tdi this morning as its not being used as been made redundant and funny enough the brake warning symbol was on the dash panel when i fired it up, but im sure he told me a few months ago he needs new pads in the front !! so there might be a link for a duff battery with the symbol
  13. itsmeagain
    434
    Front pads where changed not long ago
  14. marktdisport
    1,195
    15
    sounds like the battery or fluid leval then m8
  15. Mike B
    Mike B Well-Known Member
    1,105
    40
    If it comes on when driving its got to be the fluid level probably caused by pad wear .If the fronts were changed recently then maybe the fluid was not topped then otherwise there may be a leak.On starting it will be the electrical spike from the battery
  16. itsmeagain
    434
    Thanks for the advice everyone, I am gonna check the levels and test the battery. I only get the warning come on when starting the car, and only happened once when driving.
  17. quattrojames
    14,060
    583
    Are you talking the orange light or the red light?
    The red one in my experience is caused by a sluggish battery causing reduced pressure in the ABS pump for a few seconds when you start up.
    The orange one is of course low pad/fluid, and can also be affected by ABS sensors I believe. I have had this a few times over the last few days, pads and fluid are fine, I've checked the wiring and it looks ok - I have a dodgy light switch at the moment, and I'm going to replace that before I bypass the pad sensor as I'm not convinced the two aren't related....
  18. itsmeagain
    434
    Red warning one
  19. itsmeagain
    434
    Car is used daily, so I am gonna get the battery replaced. At least then I can rule that out if it continues.
  20. marktdisport
    1,195
    15
    dont have it replaced as un necassary costs if its not at fault m8 get it checked most places check them for free now
  21. quattrojames
    14,060
    583
    I had brake warnings, had the battery tested and it was 'fine'. I bought a new one anyway and the light stopped and the car started much better.
    It's probably worth it with winter approaching.
  22. itsmeagain
    434
    Gonna change it anyway, especially with winter quickly approaching. It's just over a year old and still under guarantee.
  23. Mike B
    1,105
    40
    A good quality battery thats just a bit low just needs a good recharge if you have the means and the time to leave it on slow charge for a 24hrs.Did this with mine and the warning almost stopped and its much less bother .Also wiggle the battery wire away from the sensor cos it was tight underneath and put some foam padding between them to insulate against the spike
  24. itsmeagain
    434
    Thanks guys for all the advice. Got the battery checked today and it's fine. It was the brake fluid just needed topping up a bit. All sorted now.
