Brake warning on startup
imported_VaulterTim Nov 22, 2005
  1. Hi all,
    As subject I have the brake warning light come on at startup. The exclamation mark with three loud chimes.
    Brakes work fine. ABS works fine, I tested /ubbthreads/images/graemlins/wink.gif
    This all seemed to start when I picked my car up from the bodyshop a few weeks ago and to be fair has only happened a handful of times since...
    Does anyone know what may be causing it?
    Dirty/dusty sensor somewhere? Maybe the cold weather? The battery went flat at the bodyshop, maybe that..?
    Tim
  2. hop2407
    hop2407 Active Member
    1,408
    Low Brake fluid ? Brake pad sensors now visible...... ?
    A couple of obvious suggestions I know......
  3. Nope, it's neither of those...
  4. When you get warining does the yellow ABS light remain on?
  5. It's not the ABS, no yellow light. It's the red exclamation mark that beeps three times.
    It only presents when the engine starts too... not when the ignition is turned on /ubbthreads/images/graemlins/confused.gif
  6. joost
    joost Active Member
    1,169
    Strangely enough, I'm having the same problem. I thought it might have been the wear sensors on the pads too.
    Be just my luck, it'll be summat that'll cost more than the car to repair (about a tenner!).
  7. easytease
    easytease cheesypeas
    433
    is the light in question not the handbrake light?
  8. No.
    Does your handbrake light have an exclamation mark and chime at you three times?
  9. madvw
    madvw Active Member
    2,489
    let me guess, iff you turn the ignition off and back on again (even without starting the engine), it doesnt happen again, nor for the rest of the day...
  10. Correct.
    Although I'm sure there was at least one occasion when it did.
    Odd.
  11. easytease
    433
    [ QUOTE ]
    No.
    [/ QUOTE ]
    i know in fords they do, and seeing as i am yet to purchase my audi, i wouldnt know
  12. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    This happens to me once in a while. Nothing to worry about. I think sometimes the ABD ECU doesnt boot up properly before the ECU does a check on it.
    Rich
  13. madvw
    madvw Active Member
    2,489
    happened to me all the time on my old A4. Especially when it had been a cold night, and then again if there had been a dramatic temperature change during the day.
    I never did get to the bottom of it. To be honest, i didn't try too hard at diagnosing it either, as the brakes were still working fine. In addition, i assumed that if it was a real problem, it would tell me every time i started the car, not just in certain conditions.
  14. Broken Byzan
    13,244
    468
    I have had it once, and that was after a dramatic temp change, i wouldnt worry unless it's re occuring
  15. PaulJC84
    PaulJC84 Owner
    2,922
    17
    My car did it for a couple of months about a year ago.
    Maybe the temp is affecting your fluid level, or just affecting the sensor.
  16. PaulJC84
    PaulJC84 Owner
    2,922
    17
    Link
    Thats the thread i posted about a while ago.
    Cheers.
  17. CJ A4
    CJ A4 Active Member
    2,664
    I got this too for a while. Started flashing every now and again then it began doing it every 30 seconds and beeping. Went and put some brake fluid in and it went away. Be sure that when you put the fluid in you have a screwdriver to push between the plastics at the mouth of the resevouir which will allow it to drain down otherwise it doesn't. Thats what happened to me anyway at the dealers. Good luck /ubbthreads/images/graemlins/wink.gif
  18. The911SC
    The911SC Active Member
    1,032
    I am pretty sure its the level sensor. I had this on my A4 and took it into the dealership and apparently it happens a lot on A4's.
    Just check that the warning comes one on a flat surface rather than a slope. Sounds obvious I know, but I just topped it up slightly and it fixed it!.
  19. cloggs
    cloggs New Member
    I had this problem about a year ago. Turned out to be a dodgy battery of all things.
    Something to do with the voltage level being too low in the controller and tripping the error.
    I would have the error everytime I left the car for more than a day or if it has been a particularly cold night.
    Anyway, I changed my battery and it's been fine ever since...
    Hope that helps,
    Chris.
  20. Hmmm, interesting.
    The car is always parked on a flat surface so I doubt it's related to the level.
    As I said before, the battery went completely flat at the bodyshop whilst the car was in having it's bit's 'n' pieces done and the fault appeared for the first time the day I picked it up from there...
    I'm not sure if they completely recharged it because I remember them having problems with their charger. I'll charge it myself then see how we go, although the fault is so intermittent that I may not see it again.
    Thanks for everyone's input, nice to know I'm not the only one with this problem.
    Best wishes
    Tim
  21. joost
    joost Active Member
    1,169
    Cheers for that fellas, couple of easy fixes to try there. I'm leaning towards the low battery charge as I've only been doing shortish trips recently and with the cold & frost, had heater/heated screen, lights etc on, also park on a level.
    Many thanks for the suggestions, much appreciated /ubbthreads/images/graemlins/ok.gif
  22. cloggs
    cloggs New Member
    I was told to check my voltmeter level before starting the car. It should show just over 12 volts, anything lower and the battery is not charging properly/wearing out. Whether that is fact or not, I have no idea.
    I think mine was reading not much over 11 volts by the time I changed the battery. Although the car would start okay, it had gotten to the point where I was always getting the 3 chimes/DIS symbol if I left the car for anything more than a few hours.
    Chris.
  23. /ubbthreads/images/graemlins/mad.gif Did it again this morning...
    It was freezing again though so no surprise... going to charge the battery over the weekend to see if that makes any difference. With snow forecast I guess I'll get to test out my theory! /ubbthreads/images/graemlins/grin.gif
    Tim
  24. funnily enough my mums smart forfour and a guy at works 1 series bmw do exactly the same.
  25. AndyC
    AndyC Moderator Moderator
    719
    timbo...
    pop it on my diagnostic kit at work.... see if there are any gremins obvious.
  26. Didn't think of that!
    Cheers bud, next time I'm down that way we'll ruffle her feathers /ubbthreads/images/graemlins/grin.gif
  27. Well... she's still doing it (intermittently still) and after a lot of investigating I have found this (stumbled across it actually)...
    WARNING LAMP FOR BRAKE SYSTEM
    FAULT: Warning lamp for the brake system comes on after cold start.
    CAUSE: In the ABS control unit is a poor recognition of low voltage and the acoustic and optical warning is activated by unsatisfactory indication suppression in the instrument cluster.
    SOLUTION: Fit the ABS unit with a low voltage relay.
    This seems to be a fairly practical solution... but we're back at the low voltage problem again. Just as a note, I haven't actually charged my battery yet /ubbthreads/images/graemlins/blush2.gif Voltage levels are fine so I didn't see any point...
    Thoughts?
    T
