Brake warning light after a cold night
Craig Cull Oct 7, 2012
  1. Craig Cull
    Craig Cull Well-Known Member
    2,429
    1,361
    Hi all, dunno if anyone's had the same problem, but since the weather started getting a little colder, I've found when I start the car 1st thing in a morning (in the garage) after a cold night, I get the brake warning light for about 10 seconds, then it goes off and doesn't come back on until a similar weather event occurs. My pads and discs are fine, brake fluid level is fine, does anyone know what's going on?? The pedal is always hard and it stops on a penny. Any chance this could be moisture getting onto the brake pad sensors? Or do I have an issue that's more serious than that? Has anyone experienced the same issue? Any help would be great, brakes are one thing I don't take any gambles with. :/
  2. ukdan
    ukdan Member
    72
    Battery needs charging or is on its way out.
    For some reason, when it's harder to start the car like in the winter months a failing battery doesn't give out as much cranking amps and the car doesn't like it.
  3. Craig Cull
    2,429
    1,361
    cheers ukdan, but I've only recently had a new heavy duty battery fitted. It's as I turn the ignition on, before I start the engine, then stays on for 10 seconds ish
  4. hades-
    9,481
    646
    does it bleep 3 times
  5. Craig Cull
    2,429
    1,361
    yes mate, but then the light goes off
  6. hades-
    9,481
    646
    im sure theres a fix for that on here
    james will prob be along and post the link i think its james that knows
    but its either low batt or the fix will sort it
    iv had it on a few audis in the cold weather.
  7. Craig Cull
    2,429
    1,361
    ok bez that's brill, hopefully it will be the fix as I've just spent £100 on a new heavy duty battery bout 2 months ago, you may remember my previous post, lost loads of power while the ecu reset.
  8. Craig Cull
    2,429
    1,361
    Same issue again this morning, if nobody else has had this problem then I better get it into Audi ASAP, don't want me brakes failing! :/
  9. Boro&Beth
    Boro&Beth Member
    172
    I've started getting this on mine over the last couple of week. Assumed it was low pads/discs but haven't had time to check properly.
    Any more info would be good.
  10. ctd
    ctd Member
    106
    mine has just started doing the same
  11. Craig Cull
    2,429
    1,361
    i have been told by the mechanics at work that its something to do with the brake sensor being near the main wiring harness. Audi made something to fix this and apparently there's a shroud that goes around the brake sensor. I'm not sure how/why or if it solves the problem but its definitely worth a shot. So.... Next question, anyone know where to get one of these?? Or if what the mechanics saying sounds correct?
  12. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    I had exactly the same problem on mine last winter, I just lived with it. Still using the same battery now.
  13. murran
    murran Well-Known Member
    1,545
    39
    must be october, the seasonal phantom low brake fluid warning threads have started. lol.
    i'll still go with what i said last year...... its the brake fluid reservoir with its integral sensor/float system. something to do with the tiny bits of water and silt in the reservoir coupled with cold weather trip the sensor on start up. change the reservoir (the whole thing).
  14. Boro&Beth
    Boro&Beth Member
    172
    It's a low brake fluid warning?
    Not low pads as I thought originally?
  15. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,320
    768
    In my experience one tends to go with the other, as the pads wear the brake piston has to go out that little bit further, and takes more fluid to do it, so as the pads get thinner, the piston comes out further and the fluid level gets lower.
  16. Craig Cull
    2,429
    1,361
    Yeah, my pads are fine and the brake fluid is all ok, I checked the basics before this post. That's why I'm confused
  17. murran
    1,545
    39
    pad warning is yellow and looks like a circle with a pair of brake shoe linings inside it and just one beep.
    brake fluid warning is red, the same symbol as above but with an exclamation mark in the middle and three beeps.
    ive replaced maybe 5/6 reservoirs in the past for this exact fault on start up. non so far this winter yet tho.
  18. Boro&Beth
    Boro&Beth Member
    172
    Do you mean you replaced 5/6 reservoirs on your car before the fault went away or you've had the same fault on 5/6 different cars.
  19. Craig Cull
    2,429
    1,361
    Whats the average price for a reservoir?
  20. GarJE
    GarJE Member
    34
    Prise out the mesh filter. Did this to mine. Haven't had a warning since.
  21. murran
    1,545
    39
    i mean im a professional mechanic, working in a garage. and ive seen this fault 5/6 times on different a4s b6s and b7s. changing the reservoirs fixed them.
    think theyre 30/40 quid for the whole reservoir.
  22. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    441
    Would you need to bleed the brakes again?? Or just a straight swap
  23. Craig Cull
    2,429
    1,361
    Even tho my brake fluid reservoir was full, I decided to top it up a touch. Problem solved! :)
