BRAKE UPGRADE
stoakseya4 Jul 20, 2007
  1. stoakseya4
    stoakseya4 Active Member
    1,221
    HI
    Can anyone recommend a reasonably affordable way of improving the braking of a B6 S4?
    Don't want to spend thousands !
    Also, am after an Avant spoiler from an S-Line ???
  2. james0808
    james0808 Active Member
    3,548
    Sorry mate but i dont think there is anything cheap for the B6 S4.
    If your discs are good you could just uprate the pads if not i would go for an RS upgrade,not cheap though.
  3. jcb
    jcb Active Member
    4,132
    13
    porsche four pots on eBay, have some caliper adapters made up and stick some RS4 or Merc discs on.
    RS4 discs will be the expensive bit
    I got delivery mileage lug mounted 4 pot Porsche brembo calipers with brand new pads for £280! Merc ML500 345mmx32mm discs are around £180/pair, caliper adapters are a bespoke engineering job, still less than £100, set of braided stainless hoses and some new fluid.
    All in £4-500
  4. james0808
    3,548
    That adds up to more than £500 + the hoses for 345mm which he has already.
    You can sell your brakes if they are in decent condition for around £250+ and put that towards some B7 RS4 monsters.
    No messing around straight fit.
  5. stoakseya4
    1,221
    What would B7 RS4 'monsters' cost then ?
    And are they a straight swap ??
  6. RS41980
    RS41980 New Member
    You will want about £1200-£1300 for B7 RS4/RS6 setup.
  7. jcb
    jcb Active Member
    4,132
    13
    not a straight swap either.
    only straight swap on an RS4 strut
