Brake upgrade question!
staitesidestory Nov 20, 2010
  1. staitesidestory
    staitesidestory Member
    53
    Hi
    Want to upgrade my brakes just wondering which set up will go straight on a 8P1 2.0 TDI sport and what else would I need other than disks pads and calipers?
  2. NHN
    29,510
    1,764
    S3, 3.2 or R32 345mm setup would do the trick, bolt on no issues on 2 of my cars now, worthy upgrade, make sure it has the brake lines as they're different to existing fixings.
  3. staitesidestory
    53
    Does it not make any difference that all those cars are 4wd? Would the rear brake set up from those cars fit aswell? Sorry to be a pain but you don't have part numbers for any of those do you?
  4. NHN
    29,510
    1,764
    No, yes & no sorry.
  5. staitesidestory
    53
    How difficult is it to change the lines is there anything tricky that I should know?
  6. NHN
    29,510
    1,764
    If you know how to bleed brakes then fairly simple tbh, as for tricky, its all down to how technical you are with these things.
  7. smudge_don
    smudge_don Active Member
    2,944
    Buy my TTRS brakes ;)
  8. NHN
    29,510
    1,764
    Bloody good idea & for the price its a steal, they are sublime brakes believe me as I've driven with them, bolt on aswell.
  9. micasb
    micasb Member
    327
    Fantastic brakes those from TTrs. Bolt on 8P but with a spacer or wider rims...
    REgards.
  10. navnayyar
    navnayyar Member
    756
    S3 brakes are a good upgrade. Have u seen the new ones forge have made? 6pot!
  11. N8
    17,163
    718
    All depends how much dollar you want to spend?
