PTTM
Pedal to the Metal!!!
Gents your expertise on brakes is required again!
I have tried to get all info by searching other threads but i still need a little more info.
I have a 2006 a3 2.0tdi 3dr and desperately need the entire brake setup replacing as im at 101,000 miles and have only replaced the pads since buying 3 years ago at 16,000 miles.
I have read that the R32 / S3 / 3.2 brake setups are 'almost' identical.
So for me to get that setup and get a garage to fit them labour only I would need to provide them with the following:
- Brake discs
- Pads
- Calipers
- Carriers
- Brake Lines
Where would you recommend I start looking and would I just ask if they have the parts for the R32 / S3 / 3.2 braking system?
Do I need the setup from the same year as my car (2006)?
As the brakes aren't intended for my car, will it take considerably longer for the garage to fit the above larger brakes rather than replace like for like?
Obviously if I cant acquire the above would some grooved discs and ebc redstuff pads be a considerable improvement on the stock brakes, which frankly suck!
Any other things I should take into consideration?
Thanks again chaps!
- Brake discs
- Pads
- Calipers
- Carriers
- Brake Lines
Thanks again chaps!
