Brake problems-Help needed plz
D8UGF Apr 5, 2009
  1. D8UGF
    D8UGF Member
    107
    Hi Folks,
    looks like I have made an ar5e of changing my rear pads on my 2003 1.8T Sport :sos: I coulndt get the piston to retract so I was told that if you keep doing a half turn outwards it will eventually turn inwards with ease. Well unfortunately I kept turning and turning until the piston came too far out, I got it back in and got it retracted, fitted the pads and all was well, but now the pedal goes in completely to the floor. I think I have managed to get air into the system :asskicking: I have read that if you have ESP and ABS you will need VAG-COM to bleed the brakes? Is this the case or can it be done the old fashioned way?
    Any info would be much appreciated
    Dougie
  2. coyote
    coyote Member
    217
    You can bleed the brakes in the old fashioned way.
  3. J7USS
    J7USS Shuddup Foooool!!
    3,731
    69
    Did you take the Brake fluid Cap off in your engine bay???
  4. D8UGF
    D8UGF Member
    107
    Thanks Coyote, so i dont need the laptop to keep the pumps cycling on the ABS and ESP?
    I did J7USS, had a bit of overspill but the level still looks good. Like the new car by the way mate!
    Is there any quirks that I should follow? Battery off etc?
    Cheers guys
  5. docurley
    4,061
    This might help
  6. docurley
    4,061
  7. evilscotsman
    evilscotsman Space Cowboy
    1,350
    13
    you can get a cheap piston wind-back tool at most motor factors / shops / halfrauds
    Thats what your supposed to use, they screw in and out.
  8. D8UGF
    D8UGF Member
    107
    Many thanks guys, got it sorted, was the rear passenger right enough.
    Thanks for the info Doc, that was the one I had been working from and got all twitchy when I read you need VAG-COM with cars fitted with ESP.
    Evil, I actually contacted Halfords and they said the one they supplied they were not selling to VW/Audi owners as there had been so many returned saying they did not work on the owners cars. I ended up getting a loan of one.
  9. evilscotsman
    1,350
    13
    sheesh halfords are no bloody use are they :)
    Glad you got it sorted bud.
