Brake pressure release solenoid (F84) intermittent
vrbob Dec 9, 2011
  1. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Just a little advice please,
    I have had the traction control light pop up on the dash a few times recently only to be fixed by turning off the car and restarting. So i have scanned the car and this is what the fault is showing :
    00812 - Brake pressure release solenoid (F84) 35-10 Intermittent
    So questions are :
    a) where do i find said solenoid and can i just try and clean it up as its not faulty just intermittent?
    b) If i need to replace it any ideas as to cost?
    cheers
  2. Greig300
    Greig300 Member
    253
    I have exactly the same problem. Intermittent to. I was told by the specalist the part is not available seperate. Its part of the master cylinder (Servo). Meaning the engine has to be removed and a new brake servo fitted. £475 part ex VAT for the servo alone....then labour. which would amount to well over £1000 time labour etc is involved. When my light comes on i just restart the car and its fine for days/weeks/months. But i do feel the brakes are not as strong as they should be.
  3. vrbob
    2,375
    171
    Ouch!
    Really is that the only option? i didnt think changing the brake stuff was that tough on these cars.
    Any one else with any more info as i do tend to trust real world (eg you guys) experience over specialists these days.
  4. jay1601
    jay1601 Well-Known Member
    1,310
    57
    check the brake light switch before you go spending ££££. only about £10 from audi. had the same sort of fault with a golf on wednesday. fitted a new brake light switch. fault is gone
  5. vrbob
    2,375
    171
    Thanks mate, i have already changed that as you say for £10 its a no brainer and the fault persists so back to trying to solve the fault i posted.
  6. vrbob
    2,375
    171
    This is the info on the ross tech wiki :
    00812 - Brake Pressure Release Solenoid (F84) [h=4]Possible Causes[/h]
    • Switch for Brake Recognition (F83) faulty
    • Wiring to Switch for Brake Recognition (F83) faulty
    • Brake Booster faulty
    [h=4]Possible Solutions[/h]
    • Check Switch for Brake Recognition (F83)
    • Check Wiring to Switch for Brake Recognition (F83)
    • Check Brake Booster
    so whats a brake booster? and how do i check it?
  7. jay1601
    1,310
    57
    the brake boost is the part behind the master cylinder
  8. vrbob
    2,375
    171
    Cheers for that mate very helpful will have a look when i get a chance and see if anything can be cleaned up etc.
  9. macpdm
    macpdm Member
    403
    Yep got the same issue too buddy with the same fault codes but not noticed anything untoward whilst driving.I think I posted something about this a while ago myself.
  10. macpdm
    macpdm Member
    403
  11. vrbob
    2,375
    171
    Well so far i have done nothing to the car and the light has stayed off for the past 10 trips in the car.
    If it comes on again i will start investigating (eg poking stuff i dont really understand with screwdrivers)
    Am guessing its not the worst fault in the world so if its an expensive fix i will live with it as it looks like all it does is stop the traction control working which canth a quick switch off and on again
  12. macpdm
    macpdm Member
    403
    "I will start poking stuff I dont understand with a srewdriver" :applaus::)
    Having the same issue Bob I would be interested to know how you go on. Mine comes on very intermittently like yours but pressing the ESP button does not seem to knock it off.
  13. vrbob
    2,375
    171
    Mines the same pressing the ESP button has no effect the only way is to turn off the car and back on again.
    Its not done it again yet so fingers crossed it will stay "fixed"
  14. Jason.s
    Jason.s Active Member
    2,879
    348
    Old i know, almost a year to the day but thought i`d raise this again instead of making a new thread.
    How did you get on with this? Anymore on the matter? Mines doing it and came up with the same codes when scanned. Sometimes it does it often and other times it wont do it for up to a week.
    Looking on ETKA on the master cylinder theres 2 sensors on it both the same thing and number called "pressure sensor ESP" part no 1J0907597B £80.83 +vat. Wondering if its that thats causing the issue and which one out of the two it`d be?
  15. Greig300
    Greig300 Member
    253
    I still have the same issue.
  16. mk1chopper
    mk1chopper Missing the S3
    1,092
    Have you fitted your coilovers now? if yes have you had the alignment checked, when I had one of the front springs changed for an MOT the ESP light came on, once I had the alignment checked and adjusted it went away. If it was the brake pedal sensor/switch your brake lights wont be working, when the original switch failed the esp light didnt come on either.
  17. vrbob
    2,375
    171
    My issue just went away and has not returned so i guess it was something very intermittent
  18. Jason.s
    2,879
    348
    Nope not fitted yet. Brake lights work as im sure the misses would have told me as she follows me most of the journey to work every morning. Light hasnt come on since sunday so we`ll see how it goes.
  19. Greig300
    Greig300 Member
    253
    The fault your receiving only will get worse and will show more frequently. It's definitely a master cylinder problem it's the solenoid internal to the servo and cannot be replaced separately it requires a new servo. It's a big job requiring the engine to be removed or dropped to gain access it's costly hence why people sell the car on or forget the issue by resetting the error or restarting the car until it shows again.
  20. Jason.s
    2,879
    348
    and you know this for a fact?
  21. Greig300
    Greig300 Member
    253
    Yes i have the same issue
  22. Jason.s
    2,879
    348
    And you`ve had someone properly identify (ie Audi or a decent specialist) that you need a servo replacing? I can see F84 on ETKA shows as a servo so just want 100% confirmation as like you mention its not the smallest of issues.
  23. Greig300
    Greig300 Member
    253
  24. Jason.s
    2,879
    348
    Pretty sh!t then. Especially considering a new servo is £500+vat...
  25. fazer0
    fazer0 Member
    50
    Has anyone else found a fix for this that doesn't require a new master cylinder or the engine dropped out.
