brake pads stuck to discs
Cpt Sensible Dec 18, 2009
  1. Cpt Sensible
    Cpt Sensible New Member
    When not in use for week or more pads can 'seize' on to discs and freeing means revs and big strain on clutch. Any alternative thoughts on freeing up .....WD 40 ?! .......Cpt. Sensible.:hi:
  2. NHN
    29,345
    1,719
    Welcome to the site
    Hot water given this will dissepate very easily with the heat generated in braking, although my mate Lea says it will expand things, but certainly harmless, but wd40 urm maybe not on discs huh considering its a lubricant to a degree, not sure the temp it would disintegrate, but tbh unless they're welded to the things a quick rock forward & back with 1st/rev wont harm it, gently though
  3. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,385
    111
    if you find that wd40 is not sufficiant enough you could try bearing grease, if this still doesnt work then i suggest you remove the pads at night and take them in doors with you
  4. NHN
    29,345
    1,719
    lmfao thats got me holding myself as its that funny, remove the pads & take them in at night, lmao, what is it, a lost puppy, lol, lmfao very funny
  5. Cpt Sensible
    Very helpful....pads into airing cupboard as well no doubt.:end_of_discction:
  6. NHN
    29,345
    1,719
    Oh come on, grow a sense of humour, afterall its xmas, wheelie was only having a joke with yer mate, lighten up a little on here will yer, its all good
  7. 1wheelonly
    2,385
    111
    not a good idea, then all your towels will smell of wd40 and your wife will go nuts.
    the radiator in the kitchen will be fine
  8. davs4
    davs4 New Member
    9
    My hi spec brakes used to do this on my S4, the cure for me was to try and come to a stop slowly, when almost stopped use handbrake, once stopped release handbrake and use in gear to stop (allows for slight roll with no front brake on). A pain in the ar** I know which is why I sold it!
  9. pjmspeedy
    pjmspeedy Dude, what's mine say ?
    1,058
    Unless there wielded on then like NHN said just move off slowly and it will be all sorted. If your that worried don't leave the handbrake on and park it in gear.
    Whatever you do, don't put any WD or grease on them... You might find that they won't stop you when pressing the pedal!!!!!
  10. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    I just leave the car in gear with the handbrake off whenever the weather is cold or I've washed the car. Never had this problem since doing this...
