brake pad warning light
jays3 Sep 8, 2008
  1. jays3
    jays3 Member
    75
    i had this light come on earlier this week so i just replaced the pads and obveously the sensor, the light hasnt gone out, any ideas,
  2. Issac Hunt
    1,162
    All connected correctly? No broken or damaged wires?
  3. jays3
    jays3 Member
    75
    no everything looks fine, would disconnecting the battery for an hour reset it.
  4. Nilz
    11,273
    845
    Doubt that will reset it, best thing to do is get it on vagcom...
  5. god_thats_quick
    2,507
    It's just a loop of wire, something's knackered between the connector and the pad if the lights still on!
  6. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    As above, wire will be split
  7. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    Make sure the connector is clicked in. My warning stayed on because I hadn't done this.
  8. abdus
    abdus Top Gear VCDS Map User
    1,827
    yep, had the same problem
