brake pad warning light even though the pads have loads left on them
DOLPHIN DIESEL Sep 11, 2010
  1. DOLPHIN DIESEL
    DOLPHIN DIESEL Member
    95
    as above realy, when i turn the key the warning beep and light comes on saying there is a fault with the pads, all pads have loads of life left in them, whats going on?
  2. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    One of the connectors has failed somewhere between the brake pad and the loom.
    They are fairly exposed next to the hub and get hit . I have the exact same problem.
  3. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    I have this problem too!
  4. DOLPHIN DIESEL
    95
    maybe i was too heavy handed fitting the coilovers then, how do i fix it? imguessing i need to find the break in connection and go from there yeah?
  5. scottie123
    1,972
    you got it.
    Wiggle all the plugs and see if you can make the light go out/come on
  6. jb0o
    2,664
    118
    Let me know how you get on mate and ill follow your lead! :)
  7. DOLPHIN DIESEL
    95
    will do this in the week and keep you informed, thanks guys
  8. Lee_R
    Lee_R Active Member
    2,499
    12
    you got cheap pads? Some of them have the sensors poorly fitted too close to the surface. Seen a pad with 3k miles on it worn to the sensor and there must have been 8mm pad on it!
  9. craig32
    craig32 Member
    176
    On my old mans db9 the brake pad warnings come on when theres still rougly 10k miles of life left in them...a bit crazy but could it be something similar?
  10. Lee_R
    Lee_R Active Member
    2,499
    12
    probably, arent the DB9 ones the same as the Mondeo Zetec? ;-)
  11. filipek
    filipek New Member
    i also have the same problem, my pads all near new and the light came on. i went to my local gsf and asked guys ther said it is possible connection on loom as this is common fault. find wher this connection is lost and get new loom. guys ther said is only cheap to replace this
  12. roman3000
    roman3000 Member
    316
    Take the sensor out and have a look at it, its probably broken or the wires to it have broken.
    You need to cut it off to get to the wires then connect them to each other and the fault will go away. Or if you still want the sensor then buy one and connect it up, its only 2 wires.
  13. olliea3
    olliea3 Member
    215
    happened about 3 times on my mk5 golf , easy to repair if you can see where its damaged
