BRAKE PAD FITTMENT ADVICE
vw754 Mar 27, 2007
  1. vw754
    vw754 vorsprung Durch Technik
    2,351
    58
    Rear and front pads need replacing soon,any special tools needed to do the rear's or is it as easy as the front?
    Also is it an allen key job or a socket set?
  2. 1210tech
    1210tech Four Ring Fanatic Team Daytona Team V6 Audi A6 Audi Avant Owner Group S-line owners group
    696
    fronts are easy but you will need a special tool to wind in the piston on the rears.
    standard socket set will be fine to do the fronts
  3. vw754
    2,351
    58
    anything else i can use to wind back the pistons?
  4. technics100
    technics100 Active Member
    850
    25
    I used a G-clamp and a pair of vicegrips, It would be easier with the tool, you can get them on ebay...always handy for the future...
    Fronts are easy..
  5. dan_b
    dan_b Member
    263
    G-clamp and vice grips is how I've done it in the past too - the genuine VAG wind-back tool is pretty pricey, although you can get generic ones from Halfrauds
  6. 46TheDoctor
    46TheDoctor Valentino Rossi A.K.A The Doctor
    312
    Hi ive searched around and euro carparts do a sealey one for £22ish. Hope this helps.:weight_lift2:
