brake master cylinder
murdoch Jan 5, 2012
  1. murdoch
    murdoch Member
    44
    just had all my brakes done, including new discs, pads, and calipers, but my fitter noticed a split in the reservoir bottle on the top of the master cylinder, is it possible to get just the bottle and not the whole thing? it's an afn if it makes a difference.
    thanks in advance
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    it was possible to get seperate
  3. aragorn
    17,960
    702
    Yeh it just pulls off.
  4. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    I had that happen after using easi-bleed without reducing the pressure first :(
    I got a second-hand one for a few quid from All Audi, it was very easy to change, and if you don't use the car for a while afterwards to allow for any bubbles to come out, you don't need to bleed anything either as you don't introduce any air into the system.
