Brake lights not working- Top light does though!
bhavin1986 Jan 27, 2011
  1. bhavin1986
    bhavin1986 BBP
    464
    Hi all,
    A quick question. Just noticed both brake lights don't work. But the top panel of small brake lights do work? The fuse is fine, and so are the bulbs. I know it can't be the brake light switch.
    Any ideas?
    Cheers, Bhav
  2. hades-
    9,482
    646
    if the fuse and bulbs are ok then its the switch
    top light always works when switch goes
  3. gavin89
    gavin89 Wana go Low gotta go Slow
    214
    Yeah if bulbs fine then its switch. Scan with vagcom if you want confirmation!
  4. bhavin1986
    bhavin1986 BBP
    464
    Damn, didn't know that the top one still works if its the switch! I just replaced it less than a year ago!
    Lessons learnt for using Euro Car Parts I guess...
    Cheers peeps, will be getting the switch from TPS this time.
  5. aragorn
    18,662
    877
    Eh?!
    How the F*!k can the middle brake light work if the switch is broken?
    Theres one switch, connected to all three lamps, if one lamps working its not the bloody switch is it.
  6. <tuffty/>
    21,956
    4,229
    I concur....
  7. SiGainey
    SiGainey Member
    506
    10
    My money's on the bulbs being blown
