Brake Issues
annuv May 8, 2005
  1. annuv
    annuv New Member
    After recently having my brake fluid change and a brake hose replaced on my S2, my brake pedal is now vibrating (pulsing) even when idle. This was not the case before the above work was completed. The work was carried out by my local main Audi dealer who are telling me this "NEW" fault is due to the pressure reservoir leaking & it needs replaced. The computer in car is showing the fault. Local independent Audi specialist says the pressure reservoir is linked to the ABS unit & that a new one should resolve the fault. I have had the car 3 months now and need advice. Main dealer is asking for in excess of £600 to resolve this!!!
  2. Rev-head
    Rev-head Active Member
    2,987
    Not to sure on this one but if you post on
    www.S2forum.com
    There will be someone there that can help and maybe get you a better price for the part
    Cheers /ubbthreads/images/graemlins/beerchug.gif
  3. imported_Doug_S2
    imported_Doug_S2 Guest
    I think it could be the brake bomb - I haven't had this problem, so not sure what it is, but you should find similar problems on the s2forum.
  4. TERB15
    TERB15 New Member
