Brake Fluid Type And Quantity - 04 Plate
SAiLO Jun 8, 2013
  1. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Hi,
    What type of brake fluid is used on 2004 2.0TDI A3?
    Dot 3? Dot 4?
    Do you use any particular brands?
    How much of it is needed when changing?
    Thanks!
  2. coreythorny
    coreythorny Active Member
    463
    74
    Normally says on the cap it self on the reservoir, failing that try the manual.
  3. JPK
    JPK Active Member
    303
    Around 1.5L if you are also doing an ESP/ABS unit flush through diagnostics.
    I would recommend using OEM fluid only.
