brake fluid - just top up?
z1mma Apr 25, 2012
  1. z1mma
    z1mma Member
    100
    Hi
    my brake fluid is below minimum, is it just a matter of topping it up or do i need to take it in to indy/dealers?
  2. ANDYTQ
    ANDYTQ Well-Known Member
    1,184
    105
    If its that low you need to check your pads they might need changing ,the level drops as the pistons move out more to compensate for pad wear.
  3. Custardsucker
    Custardsucker Member
    112
    I would also check for a leak in the system. Check the pedal is firm by decaying servo by pressing pedal several times. Pedal should then be firm with no give. If it travels to the floor then definitely get system checked by someone who knows hydraulic systems as you may have a leak that could get worse very quickly and you would then have limited or no brakes.
  4. z1mma
    z1mma Member
    100
    brake pedal is really stiff not loose, brakes seem to work fine had them replaced about 6 months ago, after checking the brake fluid again i can see like a yellowy liquid below min and looks like clear liquid (water?) above max
  5. Custardsucker
    112
    Brake pedal pumps up firm without engine running and doesn't move to floor, so hopefully you haven't got a leak. I doubt if the clear liquid at the top is water as oil floats on water so more than likely fresh brake fluid and the yellowy below min is probably aged brake fluid.
    As mentioned in an earlier post have you checked the pads as they may be towards minimum and need replacing hence why the fluid level is low. Always check the obvious things first.
