BRAKE DISCS WARPNG TOO QUICK
s3_ity Aug 8, 2012
  1. s3_ity
    s3_ity New Member
    17
    hi
    i have an audi a3 3.2 s line and the drivers side brake disc warps way too quickly, a mechanic checked it and said it could be the caliper carrier so i had this changed along with the discs costing me in total around £500, however a month or 2 later same problem now i have been told it could be the caliper itself can any1 plz shed some light as i cant afford to change things that dont need changing.
    thanks
  2. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    check with a thermometer
  3. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,474
    646
    500 for a carrier discs ?
    robbing ****
  4. jamessg1962
    jamessg1962 Member
    123
    Hi
    Have you checked that the piston is retracting after applying the brakes ? If thecalliperr piston is sticking causing the pads to continuouslyy rub the disc's this will cause disc warp.
    Jack up that side try spinnig wheel after aplying brakes a few times, it should turd freely. Also have you noticed any premature pad wear compared to other side.
    Have you got the correct pads and disc's . Some non O.E.M disc's might not be up to the job. are they vented disc's ?
    Have you replaced the pads with a hard type ?
    Hope you get it sorted mate as you don't want to be spending that kind of dough often.
