Brake Disc Upgrade
raca4 Nov 13, 2006
  1. raca4
    raca4 New Member
    22
    Anyone have any views or experience with Black Diamond Brake disc's? Thinking of going with the grooved/drilled (combination) 312mm Versions.
  2. james0808
    james0808 Active Member
    3,548
    I had these on a previous car and they was good.
  3. raca4
    raca4 New Member
    22
    Thanks, is it just a straight swop for the original audi standard 288mm or other componants needed?
  4. james0808
    3,548
    If you have 288 now you will need the carriers off a TT,S3 and some new pads.
  5. raca4
    raca4 New Member
    22
    Carriers or calipers? I was told that disc's and pads was all i needed.
  6. james0808
    3,548
    You use your original calipers but you need different carriers for the calipers to accept the bigger discs.
  7. raca4
    raca4 New Member
    22
    ahh, I see, Thanks, now i,am sucking the the right tit.
  8. james0808
    3,548
    Ignore the bit about TT and S3.You need the carriers but off an A6 30v or Passat 4motion.
