Brake Disc Rust
stoakseya4 Jul 21, 2009
  1. stoakseya4
    stoakseya4 Active Member
    1,221
    I may have found some GMBH (drilled) discs, cheap, but they have some light surface rust.
    How do you remove rust from the discs without damaging them?
    Cheers awfully...
    :greyrs4:
  2. quattrojames
    14,068
    585
    Send them to me in the boot of your car, I will return them a week later fitted and all shiney. And probably glowing :)
  3. stoakseya4
    1,221
    :applaus: :3sadwalk:
  4. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    And thinner...
    stoakseya4 I don't think you should worry about the rust as long as it is only at the surface. It will come off after you break a few times.
  5. AndymacA4
    AndymacA4 Member
    165
    Agreed, the surface rust is normal and will come off with a few brake applications. Look out for any pitting or deeper rust, this would be more of a problem. If it looks like brown dust on the surface your fine!
  6. Johnny Bravo
    898
    70
    If you really want to clean the rust before fitting them I think you can use a high granulation sand paper and gently rub it off. I do not advise on using any sort of chemicals, derusting sprays or such because they may leave a thin film on the surface that will affect breaking performances. You may end up in a ditch or rear-end someone.
  7. quattrojames
    14,068
    585
    I would use a fine wet and dry paper with water, 800 or 1200 to clean the parts the brake pads don't touch :)
  8. no_idea
    no_idea Active Member
    233
    51
    How about a green or burgundy Scotch Brite pad or even a saucepan scourer.
