Brake Disc Change
chrisn900 Dec 14, 2009
  1. chrisn900
    chrisn900 Member
    77
    Hi All
    I've an 06 plate 2.0tdi se sportback (140bhp)
    It's done 71000 miles and will soon be due a front and rear disc and pad change.
    I don't really want to have to take it to the 'stealers' and wondered if it's fairly easy to do the work myself.
    I'm fairly competent in automotive work, as i did work in the motor industry for 10 years until we were closed down by incompetent management !
    Could I possibly glean some advice from members on the size of discs (think the fronts are 288mm) rears not checked yet. The best priced place to get them from, and any tips and trick changing the discs.
    I did my last car (rover 25) for about £60 for the front 2 discs and pads.
    I know the Audi will be more expensive and different, but would be grateful for any good advice.
    Thanks very much : )
  2. Paul_c
    Paul_c Member
    139
    I'm in a similar position to you mate.
    I think the rear are solid and 232mm in diameter and the front are vented 288mm. The same as the 8L i believe??
    If it is then a mintex full set is avalible for £115. :eyebrows:
    I was waiting for somebody to confirm this in another post.... :confused:
    ..... ooo just noticed you're a 2.0TDi.... mine is only the 1.9TDi
  3. jb0o
    jb0o North East Forum Moderator Regional Rep Site Sponsor VCDS Map User
    2,664
    118
    When I sold my 04 1.9TDI I did a front disc and pad change and that bill came to £50.
    They were the cheapest stuff available mind... were from an Autoparts shop.
  4. chrisn900
    chrisn900 Member
    77
    would there be any special tools I'd need for this job.
    Cant seem to find a Haynes type manual at all for the 8p....is there one available ?
  5. phil76
    phil76 Active Member
    572
    40
    Euro car parts do original ATE's i think so they could be an option,the only other thing is the caliper windback tool if i am correct and cant remember if it has a big torx drive for the caliper
  6. jb0o
    2,664
    118
    Yeah, you need a caliper wind back tool... worth the hire tbh, I paid £5 deposit and £1.75 hire of the tool, and makes the job 10x easier than using a C clamp or similair.
