Brake Bleed Order 2.0T FSI Quattro
Phase Nov 2, 2009
  1. Phase
    Phase A3 2.0T Quattro
    Hi All,
    First post here as I have recently picked up a 2.0T FSI Quattro, 2005.
    The brakes are soft, so probably need a bleed. Does anyone know the bleed order?
    Thanks,
    Tim
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,404
    543
    I am not familiar about what you mean? whats the bleed order? never heard of it!
    Do you mean in any wheel/brake in particular order?
  3. Lee Goodall
    Lee Goodall Active Member
    2,279
    The idea on all cars is to start from the caliper furthest away from the brake fluid reservoir and work your way to the closest point. Eg.. Nearside rear, then offside rear, then nearside front and then offside front.
  4. Phase
    Thanks for the replies.
    When I say bleed order, I mean the order in which the brakes needs to be bled.
    I know the general rule for most cars is for furthest first working towards nearest, but I believe the order is slightly different on these. I have heard that the system works diagonally and you must start with nearest to the master cylinder followed by furthest.
    Does anyone have a maintenance guide or manual for this model?
    Tim
  5. Lee Goodall
    2,279
    Oh I see. I that case ignore what I said lol.
    Hopefully somebody will have the correct info to hand.
