Brake Bias settings
max69vk Apr 22, 2013
  1. max69vk
    max69vk Active Member
    862
    57
    After replacing some rather shockingly worn brake pads on the motor at the weekend I've noticed that the brake bias seems to have shifted more towards the rear of the car. I've checked the fitting & cycled the ABS & its made no difference, after doing a bit of online searching it appears that the braking bias is meant to be set more toward the rear for safety i.e to keep the car more level under braking?
    I cant say that I'm 100% that this is correct as I used to get a fair bit of nose dive under heavy braking before the new pads were changed fitted (though this could be down to the knackered pads. The car stops fine enough although it does feel a bit strange as if being dragged to a stop rather than the previous nose-diving, dont get me wrong I've tried some heavy braking and the front brakes & ABS do kick in + a couple of hundred motorway miles & the brakes were working very well at slowing from high speed. Its just the balance feels a bit 'weird'.
    Does anyone else have any further knowledge on this?
  2. crunchie
    crunchie Active Member
    880
    77
    My S3 shows a lot more brake dust on the rear wheels compared to the fronts.
    Stripped them down a couple of times and stroked full length on the pistons and they are free as a bird.
    Don't remember them being quite as bad 2 years ago when I bought it with 12k on the clock, its now showing 26k.
    I wasn't sure if there was a load compensator as such on them?
  3. nluk100
    nluk100 Well-Known Member
    1,035
    192
    Really? My fronts are always caked and the rear ones are virtually clean!
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    im the same, id say it was time for a caliper refurb for the op
  5. max69vk
    862
    57
    I think there's a possibility the front pads are just taking a little longer to bed in than the rears, although at lower speeds the rear brakes appear to be biting reasonably equally with the fronts which gives a much more 'level' stop i.e. no nose dip/dive. At higher speeds or emergency braking the front is definitely working harder & there is the expected dip/dive & ABS kicking in under very heavy pedal use.
