Braided Brake lines
dela Mar 22, 2010
  1. dela
    dela Member
    262
  2. Andrew@A.L.D
    3,877
    617
  3. Barks
    Barks Member
    337
    Same as the ones I have brought, make sure you have the 2 banjo fittings and 4 copper washers (new) can't see them in the photo,
    damage looks OK, just to the outer cover
  4. jonny87
    jonny87 Active Member
    1,094
    yer damage is just to the plastic covering the actual metal braid, it would pay to have it recovered though as after time the dirt/grime/water etc will start to affect the hose
    bit of a bargain there though mate, banjo fittings and copper washers can be had from halfrauds
  5. dela
    dela Member
    262
    sounds good to me. so just to clarify it is the front and backs?
  6. rossbrownlee
    rossbrownlee Ross_S4
    719
    To be honest mate i would steer clear.
    The 'slight rubbing' referred to in the description - There has obviously been some fairly significant abbrasion to the outer cover to cause damage like that shown.
    In my work our stainless braided flexi's are subject to 6 monthly inspection from the hose manufacturers, the criteria is pretty strict, any braid damage (broken braid, abbraided, corroded etc) and the hose is replaced asap.
    IMHO I would steer clear of fitting these to my brakes but at the end of the day it is up to you.
  7. dela
    dela Member
    262
    bloody hell, as its only on the outside and not acctualy damaged braid do you not think it would be ok? ill deffinitely look into recovering it if i do use them
  8. Matt82
    Matt82 Active Member
    2,365
    wrap some duct tape round that adn youre done, surely?
  9. jonny87
    1,094
    mate if it were me id use them, just throughly check the braid and have it recovered and all should be well
    BUT
    if theres any sign of wear on the braid then i wouldnt risk it because if it bursts under braking you're gonna lose all your brakes, bad times!!
  10. rossbrownlee
    719
    Well really the inner hose (something like ptfe teflon or equivalent) should be rated for the pressure that you throw up it, with the stainless braid providing reinforcement and some protection. as previously posted, it is your choice. Everyone on here may give you opinions or information but at the end of the day it is down to you to decide.
    This may not be so easy. The outer covers of this type of hose are extruded onto it during manufatcure. any recovering you manage to get done will not be like the standard cover. if you are not bothered about the appearance then happy days.
  11. rossbrownlee
    719
    and another thing...
    hel offer a lifetime warranty on their hose kits. might be worth a cheeky punt, "hey the cover has come off my hose!!"
