BOV sound when changing gear/letting off throttle 2.0 TDi s line Quattro
lewi89 May 20, 2014
  1. lewi89
    lewi89 Member
    44
    13
    hey guys/gals
    as above...
    i'm getting a sound very similar to a BOV when changing gears/letting off the throttle and it's rather loud. Took it to the garage yesterday and they couldn't find the issue, although they agreed there is one.
    I'm also down on power, in my opinion, but the guy that took me out didn't seem to think so. It just didn't feel right, felt like a N/A 2.0 rather than turbo.
    anyone else had this problem?
    any help appreciated
  2. lewi89
    lewi89 Member
    44
    13
    anyone? haha
  3. SmithyAG
    SmithyAG Active Member
    414
    61
    Has it always done it or has it only just started?
  4. lewi89
    lewi89 Member
    44
    13
    started on Monday mate. taking it to the garage next week but don't want them to con me, so thought i'd get some advice!
  5. max69vk
    max69vk Active Member
    862
    57
    Check the vacuum line that comes from the N75 to the air filter box hasn't split or come off.
    lewi89 likes this.
  6. fdacic
    fdacic New Member
    22
    I think i have a similar sound, i think i had the sound for ~2 years, please keep us updated with your findings
  7. S3 TDI
    S3 TDI New Member
    17
    The N75 valve if blocked will cause this issue . Remove the vaccum line that comes from the N75 valve into the airbox and blow a bit of compressed air into the N75 valve. Usually they get a bit dirty and cause a dosing/flutter sound and the ECU puts the car into a limp mode situation. It's basically cutting boost from the turbo . Try cleaning it out and see if it helps otherwise you might have to replace it . Let us know what happens
    lewi89 likes this.
  8. lewi89
    lewi89 Member
    44
    13
    It's off to the garage tonight (covered under warranty) i'll keep you updated. They have another A3 s line quattro going in tomorrow, so they are going to swap parts to find out the issue exactly.
    i'll let them know about the N75 Valve/Vaccum line.
    ESP Light is also getting sorted. I believe the sensors are the problem with this though and it's a common issue?
  9. S3 TDI
    S3 TDI New Member
    17
    SOunds good. let us know what happens. Also forgot to ask do you have an aftermarket intake or the stock one ?
  10. lewi89
    lewi89 Member
    44
    13
    It's the stock one at the moment as the modding hasn't started yet. That will be at the start of next month, but I need to get everything in check before upping the power etc.
    With a bit of luck it will only be in the garage for the day and I can collect it tomorrow evening *fingers crossed*
  11. a3_Ollie
    a3_Ollie Member
    86
    any update on this? Mine feels as if it does the same
  12. lewi89
    lewi89 Member
    44
    13
    No update as of yet. I did call the garage this morning but they haven't found the problem yet...
    Going to call again in the next 15-20 mins to see what is happening. Can't handle driving this Nissan Almera '02 plate any longer (a day is long enough) :puke2:
  13. lewi89
    lewi89 Member
    44
    13
    Just spoken to the garage and have been told they have sent the codes to Audi Aberdeen. The mechanic was more than happy to give me the codes though to enable me to do some digging, a lot of garages i've spoken to before seem to be reluctant!
    There are 2 of each code... not sure what that means though exactly! one is for the ESP light being on, I believe?
    A simple search on the Ross-Tech wiki gave me these results.
    Not sure how bad these are in all honesty, or if they are simple fixes?
    16347 - Control Module - EEPROM Error
    Possible Symptoms
    Control Module doesn't perform to factory design
    Possible Causes
    Wrong Firmware Installed
    Failed Control Module
    Possible Solutions
    Update Firmware of Control Moudle
    Replaced Control Module
    Special Notes
    When found on:
     VW ABS modules, see TPI 2017922
     Bosch 8.0 ABS module, see TPI 2008907
     Skoda with Bosch 8.0 ABS modules, see TPI 2014687
     Audi A3 or TT Steering Assist, see TPI 2021189
     Audi A8 Electronic Parking Brake, see TPI 2016072
    02248 - Valve for Controlling Clutch Operating Angle (N373)
    02248 - Valve for Controlling Clutch Operating Angle (N373): Mechanical Faulty
    02248 - Valve for Controlling Clutch Operating Angle (N373): Mechanical Failure
    Possible Symptoms
    Malfunction Indicator Light (MIL) ON
    Possible Causes
    Fuse(s) faulty
    Valve for Controlling Clutch Operating Angle (N373) faulty
    Possible Solutions
    Check Fuse(s)
    Check/Replace Valve for Controlling Clutch Operating Angle (N373)
     Check Measuring Value Blocks (MVB) for proper Supply Voltage
    Special Notes
    Valve for Controlling Clutch Operating Angle (N373) may be part of the All-Wheel-Drive/Haldex Control Module (J492) and cannot be replaced separately, a Repair Kit including an optimized Control Module may be available though.
  14. MAD_Adamski
    MAD_Adamski Member
    344
    Mine makes like a bov noise but mine has a turbo back exhaust remap and egr delete I didn't get the noise really before all this so I can only put it down to turbo noise coming through now..... I have no power loss tho.... My cosworth has always sounded different too depending on exhaust and air filter used and amount of boost etc....
  15. fateman
    fateman Member
    58
    Have you resolved the BOV-like, sound? I am having similar problem on my 1.9 TDI (BKC), however I do not register any power losses whatsoever. Just the sound, which was fine at the beginning, but it has become more of an annoyance by now. We thought it was a rusty exhaust mounting at the beginning, however after changing it, the sound didn't go away.
  16. lewi89
    lewi89 Member
    44
    13
    Still hasn't been resolved mate. I've spoken to the garage and they are unable to fix it themselves so have sent it to an Audi Specialist this morning. Been told they will update me tomorrow, but I'm going to call later on this afternoon.
    I'll keep this thread updated with any useful info I receive.
    Been told by angel tuning they can remap my car tomorrow too, so I'm gutted. Will have to rearrange that!
  17. fateman
    fateman Member
    58
    I have recorded the issue on my phone, someone might be able to tell more from the sound of it. I wonder if the sound is the same as you are having.
    Owl in the engine
  18. MAD_Adamski
    MAD_Adamski Member
    344
    Boost leak perhaps have you checked the hoses ie cooler hoses and boost valve hoses....
  19. Keram
    Keram Active Member
    245
    41
    I have exactly same sound, but much louder because of back box delete :) I think you shouldn't worry, I work in car service and quite often see cars doing sound like that. If I'm correct, that is normal wastegate operation, or not ?
  20. heap1000
    heap1000 Member
    158
    have the same noise here. had it for over a year. did mention it once when it was in for a service and they checked the pipes for a boost leak and also took it out and they said it seemed to be boosting fine but they could not hear the noise! soon as i got back in the car and drove it the noise was there!
  21. lewi89
    lewi89 Member
    44
    13
    That's an accurate description haha! but yeah, it's very similar to that. wasn't noticable at all when i first purchased the car. but now all hell is breaking loose power wise! Unsure if related to be honest...
    can't get through to the garage this morning though, so will update all once i manage.
  22. lewi89
    lewi89 Member
    44
    13
    UPDATE:
    The reason the power is down is because the Haldex Control Module has decided it doesn't want to be on this planet anymore.
    Going to be a couple of days until I get the car back :( that'll be a week tomorrow I've been without it.
    Still waiting to hear back about the owl that lives in my engine bay too...
  23. fateman
    fateman Member
    58
    Sorry to hijack your thread again. :) I thought it would be good to have complex info on the issue in one place. I hope you don't mind, however if you do I will start a new thread, no probs :)
    So I did a turbocharger VAGCOM scan and logged the pressures both actual and specified for a pal on my local forum who said it would be good to see in what state the turbocharger is. But since I have them I thought it would be good to get more heads to have a look at it. Is anyone able to interpret them for me? I read something on Rosstech site but I am not sure I understand what they are saying.
    This is a run from standstill to over 4000RPM at 3rd gear:
    And these two are ordinary test drives trough the city:
    If you would prefer raw data, they can be found in the following zip container: https://www.dropbox.com/s/4ws29z66lc3q0qw/logs.zip
    And since it is the same issue my brother ask me to ask for the opinion on his Octavia with the same engine (BLX code though) He is having the same issues as I am. Logs in the zip file: https://www.dropbox.com/s/x1zjsb3hahxoet1/LOG-octavia.zip
    Thank you!
  24. fateman
    fateman Member
    58
    Any news regarding your issues? I have been researching the issue and it is either Turbo Actuator giving away or there is a crack/hole in my exhaust, which I didn't have a chance to look at it lately and a brief inspection showed no cracks, but it really was a very brief one:)
  25. lewi89
    lewi89 Member
    44
    13
    completey forgot about updating this!
    the power loss was due to the Haldex Module failing, so i had to get a new one fitted.
    the whooshing noise however, they think it is a loose o ring, but couldn't find out which one it is :/ so i'm stuck with the noise for now.
    i'm completely stumped what to do tbh
