Bov or forged diverter????
Rbarlow93 Feb 10, 2013
  1. Rbarlow93
    Rbarlow93 New Member
    9
    I will be getting my first audi on monday and I love the sound some turbo cars make and I want my audi to make that sounds I saw the hks ssqv kit that on the 1.8t but also the 007p forged diverter what is my best route
  2. Bradderz_1988
    3,951
    235
    Upgraded diverter valve anything else and you will have running issues !!!
  3. Rbarlow93
    9
    Well if I upgrade my diverter valve will it make that noise when it spools and which diverter should I get
  4. Bradderz_1988
    3,951
    235
    I run the forge 007p but you could go for the 008 !!
    only way you will get spool noise is if you mod the airbox below the filter or fit a cone filter which deletes the airbox some people disagree with running them but i run one it down to you which way you go the honda s2000 mod looks good as its a paper filter in a cone shape sodoesn't need to be oiled but will need some sort of piping that has a bigger id one end as the filter has a 3" kneck iirc
  5. Rbarlow93
    9
    So what would happen if I ran the hks ssqv kit made for the audi
  6. Bradderz_1988
    3,951
    235
    When you change gear or back of the throttle and the ssqv 'dumps' the MAF sensor has already accounted for that air and the ecu has matched that figure with the amount of fuel to be injected, so you end up getting a few seconds of the car running rich its bery noticable when at idle if you blip the throttle the revs will start to hunt !!
    Stick to a piston type diverter and you will be problem free as long as you service it every year. If you the dumping/spool noise you will have to remove the airbox or mod it !! You could fit the forge splitR which will give you more audible dumping noise but no spool noise !!
    and you haven't said what car your getting audi 1.8T ??????? LOL
  7. Rbarlow93
    9
    Yes sorry the 1.8t it already has k&n intake borla exhaust awe tuning and short shifter unknown on brand only 92,000 miles its a 01 quattro im excited
  8. steady jay
    steady jay Member
    184
    My 1.8t is running a cone filter with quite an aggressive map by that I mean it's not gradual just loads of lag then boooost. The chatter from my k&n is quite loud. Probably not a good thing but so many problems with my car I've given up caring
  9. Bradderz_1988
    3,951
    235
    Chatter ?? What DV you running ??
  10. Rbarlow93
    9
    Well im gonna look into the diverter valve what are some good ones
  11. steady jay
    steady jay Member
    184
    Sorry wrong word *flutter
  12. Bradderz_1988
    3,951
    235
    Sure your DV's not shot ???
    AR-rkon likes this.
  13. Rbarlow93
    9
    Is a 007p any good
  14. steady jay
    steady jay Member
    184
    Could well be but penny valve is knackerd so it's being driven until it dies
  15. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    165
    im running a 007p with a green spring, seems (IMO) to hold boost better, be a bit smoother and quicker than the 710n...
  16. Rbarlow93
    9
    And does it make the turbo and louder with the 007p
  17. AR-rkon
    1,913
    165
    No, as Bradderz has said further up, you would need to do the drilled airbox mod, or fit a cone/mushroom filter (with adequate heat shielding).
