bought new cam follower, fuel pump looks different to one in video
JJ.Foulds Aug 22, 2013
  1. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    So iv got my new cam follower and i was going to try replace it, however after watching this tutorial video
    DIY: 2.0T FSI Cam Follower Replacement on Vimeo at 4:30 he has a bleeder valve, mine does not have this and has a metal pipe connected around that area instead.
    Its an 05 2.0 TFSI. so not sure what to do now, would i be able to leave them attached and still replace the follower? or would i break something.
    Thanks JJ.
  2. JJ.Foulds
    1,263
    176
    the 2 pipes on the bottom, where on the video it has a bleeder valve, what do?
    Uploaded with ImageShack.us
  3. hades-
    9,481
    646
    its only to let the preasure out
    just pull the fuel pump fuse start the car all preasure is gone
    then remove pump etc
  4. Marc8490
    Marc8490 New Member
    21
    Have you fitted your fuel pump yet? Either on your new 1 or probably best on your old one once you've removed it could you do me a favour? The union on the bottom at the right hand side could u take that union off and tell me if there's anything inside it? Removed mine by accident and heard something falling into the engine bay but cant find anything, thinking there's possibly a tapered pin in there
  5. JJ.Foulds
    1,263
    176
    Yeah i saw your thread and got worried when doing mine, thats why i went to check and noticed it was diffrent. Is yours the same pump as mine?
    JJ
  6. hades-
    9,481
    646
    there shouldnt be anything in the union
    iv remved quite a few and never seen anything in there
  7. Marc8490
    Marc8490 New Member
    21
    No i had the bleed valve on mine, like bez said start it with the fuse pulled, my car had been sitting all night and went out this morning to work on it and there was no pressure behind the bleed valve.
    but i removed the union when i didnt need to doh ha, just dont take the union off u only need to take the hard pipe off of the union, but if you could take the union off once uve got the fuel pump on a work bench and tell me if anything is in there behind the union that would be a massive help
  8. Marc8490
    Marc8490 New Member
    21
    Cheers bez, hmmm something fell in to the engine bay about the same time i took the union off, make it was just a coincidence and it was something totally different, also feel there's a lag in the throttle response since i changed the follower, mabye there's always been lag ive just never noticed it :/
  9. hades-
    9,481
    646
    have you got VCDS ?
    if there was a fault at the HPFP it would have a fault code stored
  10. Marc8490
    Marc8490 New Member
    21
    Yeh i do, but last time i tried using it there was something up with it, ill try it again tho
  11. crunchie
    crunchie Active Member
    880
    77
    Hmm, I might tackle this too.
    58 plate S3 with 29k, is it worth doing it?
  12. Marc8490
    Marc8490 New Member
    21
    Mine is 07 70k miles and i would say it wasnt that bad, but I don't know if it been done b4, possibly has
  13. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
    I believe the risk is low but just for piece of mind and the cost of it its worth doing.
  14. XFi
    XFi In need of a V8.
    491
    47
    I have a 58 S3 and I changed my cam follower about 3000 miles ago at 70k. The old one was fine with minimal wear but for £25 and peace of mind it's worth doing.
  15. JJ.Foulds
    1,263
    176
    Mine has 120k on it and no idea if it has been done before... :O
  16. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    I change mine every 10k alongside with the oil service.
  17. Dave_G
    Dave_G New Member
    12
    Mine has failed badly at 72k so I would definitely be checking on changing them
