bought [ brough74 ] S3 but got few Q's now :/
z1mma May 11, 2012
  1. z1mma
    z1mma Member
    100
    [FONT=&quot]Hiii
    finally after looking around got ME a S3 thanks to Audi sport!
    here’s the run down on specs,[/FONT][FONT=&quot][/FONT]
    [FONT=&quot]AUDI S3 2.0T FSI QUATTRO 2008 with 19000 Miles [/FONT]
    [FONT=&quot]In stunning Metallic Phantom Black with black leather interior[/FONT]
    [FONT=&quot]Manual 6spd gearbox[/FONT]
    [FONT=&quot]GSM mobile phone prep[/FONT]
    [FONT=&quot]Multi-function flat bottom steering wheel[/FONT]
    [FONT=&quot]Xenon headlights[/FONT]
    [FONT=&quot]Heated front and back seats[/FONT]
    [FONT=&quot]Satellite navigation plus[/FONT]
    [FONT=&quot]IPOD connection built in and Aux in[/FONT]
    [FONT=&quot]Rear parking system[/FONT]
    [FONT=&quot]Cruise control[/FONT]
    [FONT=&quot]Climate control[/FONT]
    [FONT=&quot]Bose sound system[/FONT]
    [FONT=&quot]Space saver wheel[/FONT]
    [FONT=&quot]Sunroof[/FONT][FONT=&quot][/FONT]
    [FONT=&quot]Privacy Glass[/FONT]
    [FONT=&quot]Electric/heated door mirrors[/FONT]
    [FONT=&quot]Auto lights and wipers[/FONT]
    [FONT=&quot]Auto dimming mirrors[/FONT]
    [FONT=&quot]Isofix[/FONT]
    [FONT=&quot]Full Audi service History #on long service#[/FONT]
    [FONT=&quot]Lowered 25mm on H&R springs[/FONT]
    [FONT=&quot]10mm spacers on the front and 12mm on the rear[/FONT]
    [FONT=&quot]Cupra R front splitter, easy to remove if not to your taste[/FONT]
    [FONT=&quot]RS6 Front grill[/FONT]
    [FONT=&quot]Darker rear lights #genuine Audi#[/FONT]
    [FONT=&quot]Genuine Audi mats[/FONT]
    [FONT=&quot]Later spec alloys with Michelin pilot sport tyres 5mm front, 6mm rear[/FONT]
    [FONT=&quot]
    that’s the exterior and interior done... I don’t know if its slandered on all s3's or not but all the inside are like the black edition models, black interior, dials, mirrors sunroof buttons etc...
    Milltek exhaust with black tips, Not the loud one [/FONT]
    [FONT=&quot]Induction kit[/FONT]
    [FONT=&quot]Upgraded fuel pump with new cam follower[/FONT]
    [FONT=&quot]Uprated sach clutch [/FONT]
    [FONT=&quot]RS4 Fuel pressure regulator[/FONT]
    [FONT=&quot]Later spec “D” Recirculating valve[/FONT]
    [FONT=&quot]Revo stage 2+ Software[/FONT]
    [FONT=&quot]Approx. 360 BHP and 360lbft [/FONT][FONT=&quot]
    with all those mods its pulling 360bhp BUT it feels like it’s not :s
    a friend of mine has stock 58 plate s3 and raced from 3rd gear and he kept up with me all the way on a few occasions started to even edge forward... his is a facelift model and about 30k on the clock and a manual, I think his a member on these forums too.. ( yooo! lol )
    so maybe a bad map? any advice?
    also, at low revs when the car drives in 2nd gear without gas/clutch, the car makes like this knocking noise from the engine as if something is loose, is this normal? a few people as well as stealers believe it is, can someone confirm?
    lastly, breaks squeaking... I had these checked and pads have a lot of life left... but when just pressing the peddle firmly the brakes squeak.. what could this be??
    your thoughts much appreciated
    z1mma[/FONT]
    [FONT=&quot][/FONT]
  2. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    604
    Hi z1mma lovely spec car as i,ve seen and been in it, map was fine pulling right through the gears , best to scan car using vagcom , or if your near sheffield get it down to statllers get it check out , they also have a rr and if there is a problem with map it will be covered under some sort of warrenty ..
  3. Rob W8
    Rob W8 Member
    953
    I suspect the Revo map could have been set back to standard or turned down. Find someone with an sps and get it turned back up. No way could a standard car keep with a stage 2+.
  4. Kelza
    3,078
    604
    z1mma i have a sps switch as i remember the car could be set up to default settings from the tuners ..
  5. MartayMcFly
    MartayMcFly Booooooost Regional Rep VCDS Map User Gold Supporter
    2,749
    352
    Brakes squeaking isn't wear, it just needs a dab of grease behind the pad (inside edge to the caliper).
  6. Kelza
    3,078
    604
    Hi there make sure your running 97 ron or higher as i only use vpower petrol , maybe try some injector cleaner , and also best to get the car checked out by someone like statllers an audi specialist ..
  7. Kelvin_S
    Kelvin_S Member
    243
    Well I guess 80bhp isn't really that much more, It can easily be canceled out by Bad shifting, weight difference or turbo on it's last knees.
  8. brough74
    brough74 Member
    423
    22
    I always used 97 ron and its been fine and its had injector cleaner fluid when the map was done. apart from that as you felt on the test drive it pulled well. As for the knocking noise you mention i dont know unless its just the clutch grabbing as you have no throttle on.
  9. z1mma
    z1mma Member
    100
    had to use normal petrol due to accident on motorway and fuel gage showing 10 miles in stop/start traffic lol... so maybe due to this then? but it makes that much of a diffrence?? the guy i raced was using normal petrol too.. i need to find a rolling road in birmingham and take it from there
    the knocking its not like as if its about to cut out or anything, more like a thuding lol, and only happens further slowing down during snail pase..
    apart from beeing a lil paraniod, im in love again :D the car is a beast, and very very happy with the investment!! :D
  10. MartayMcFly
    2,749
    352
    Using 95RON would show less power on a standard S3, the effect will be multiplied significantly on a modified car. Get some V-Power in there and see if your friend can keep up.
  11. z1mma
    z1mma Member
    100
    [​IMG][​IMG][​IMG][​IMG]
    MartayMcFly likes this.
  12. MartayMcFly
    2,749
    352
    Christ I want that grille!
  13. Kelza
    3,078
    604
    Thats what i thought you have put in normal petrol this with pull the timming back , like martin said get some vpower straight away ,and get a sps switch as well ...stunning car, welldone ...:)
  14. RedDejavu
    RedDejavu Well-Known Member
    1,802
    333
    I'd of removed the spliter, makes the car look a bit odd with lowered suspension. Fuel is crucial when it comes to tune a car:
    Facts about high octane petrol - YouTube
    However 80bhp difference can be due to engine device fault, split intake pipe, overboosting turbo, exhaust sensor failure etc. so best is to get it checked via VCDS and put on a RR.
    On top of that if it was me I would rather bought it standard and do all the bits myslef with garage that I trust and could do all the checks before and after just for peace of mind and tuning fun factor:].
  15. z1mma
    z1mma Member
    100
    tuning fun factor will come into play when i get bored with stage 2+ and move on to 3 :blackrs4::scared2:
    Kelza likes this.
  16. S.
    S. Well-Known Member Team Ibis TFSI Owners Group Audi S3 quattro Manual
    1,975
    537
    did you maybe disconnect the battery? or maybe car went into a limp mode?
    you should plug in vcds and see the boost values.
    does it use more fuel than usual and do you get burbles noises from the exhaust when you leave the throttle in 2nd gear?
    if so i got the last issue too, car is going on monday to a garage to see what's wrong.
    and once i felt lack of power then i used vcds and saw that boost is 1.2 bar which is i think stock did a throttle body adjustment and it vent back to full boost.
