Bottom of the S3 door.
DJ-S3 Apr 2, 2013
  1. DJ-S3
    DJ-S3 Active Member
    690
    43
    Think my other half has opened the door onto a high curb or something, (taken a notch out of it) basically, it looks like the bottom part is just screwed on. Anyone know where to get a new one? A part from Audi...
    Dom
  2. NHN
    29,596
    1,782
    Best option is audi tbh unless you find a breaker with one, I'm sure you want it to look as good as possible, but they need painting if bought new, talking about £50 from dealer plus paint.
    Cant you just get it filled & touched in.
  3. DJ-S3
    DJ-S3 Active Member
    690
    43
    Ok, cheers Nigel. Thought you'd pop up and advise me what was best to do :D
  4. NHN
    29,596
    1,782
    Pic?
  5. TDI140
    TDI140 Well-Known Member
    1,632
    175
    The bottom part of sportback doors come off usually held on with the two screws on the inside of the door and also may be some adhesive which comes off i cant quite remember but the small strip at the bottom of the door definatly came off on my sportback rear door as i also had a passenger hit a high curb
  6. TDI140
    1,632
    175
    Also forgot to add i remember audi charged quite alot for the piece as my body work guy said and he found a replacement door in same colour and swapped the part so worth a check on ebay for a car breaking theres a couple s3's on there breaking
  7. NHN
    29,596
    1,782
    No adhesive, just slides on & of after removing the 2 screws.
  8. TDI140
    1,632
    175
    Ah right i couldnt remember
  9. DJ-S3
    DJ-S3 Active Member
    690
    43
    Haven't got a photo, car is at a friends garage having some work done, thought I'd just ask. Will get a pic up when I get it back.
    Oh great. Hope it's not that expensive...
  10. DJ-S3
    DJ-S3 Active Member
    690
    43
    anyone know what the part number is? Or what it's even called?
  11. NHN
    29,596
    1,782
    Just get it smart repaired, for that its not worth changing part & painting all again.
    wuta3 likes this.
  12. DJ-S3
    DJ-S3 Active Member
    690
    43
    Not sure what a smart repair would be? I can bend the silver part back and forwards. It's like a very bendy plastic that doesn't have the same shape or smoothness as the rest. Hard to explain.
  13. phil77
    phil77 Member
    56
    That would not cost much for a smart repair. Try revive and get a free quote they are good.
  14. Ash187
    7,524
    759
    thats the S3 door blade
  15. NHN
    29,596
    1,782
    You could remove the trim & give it to a bodyshop or smart repairer to do of the car anyway, I would for that small amount of damage, tbh, you could buy some P38 from Halfords & wet & dry, then fill, sand smooth to profile, then buy your paint/lacquer 2 pack from audi, I reckon you'd get away with that.
  16. DJ-S3
    DJ-S3 Active Member
    690
    43
    Cheers everyone. Will try a repairer.
