BOSE Connector help!!!
KillerUK0 May 23, 2009
  1. KillerUK0
    KillerUK0 New Member
    Hi everyone,
    im just lookin for a little help with the wireing of the bose amp and sub.
    i have 2x amps, 2x 12" subs and 2x 6x9's from my previous car which i am looking to install to my 2001 S3.
    i have the concert II head unit.
    from what i can see the easiest way to install this would be using the bose connector in the boot, i have a high level to low level converter to connect the rct leads but i cant figure out what the wires in the red block in the boot are.
    can anyone help out with what pins do what.
    Thanks in advance :s3addict::salute:
  2. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    If you have a red connector on the sub then you don't have Bose. The Bose connector is black. The Bose sub also has 2 x 4" drivers, whereas I'm guessing yours has a single 6.5" driver (which is the standard non Bose sub).
    Here are the pinouts of the red connector, BTW you don't need to use a hi-lo converter (hideaous as they are) as you already have left & right pre-outs on the red plug as well as a remote on. You will obviously need to run power fom the battery. PM me if you need instructions on the easiest way to do this on the S3.
  3. KillerUK0
    ok thanks AndyMac, so where do i connect the subs amp rct cables to??
  4. AndyMac
    9,832
    46
    Right pre-out, left pre-out and screen
  5. beameup
    beameup New Member
    22
    Is the plug the same on yhe a4 B6 advant:idea::idea:
  6. AndyMac
    9,832
    46
    No it's completely different, here's the pin out for non Bose:
    Or this one for bose:
