Bose Audio
rub a dub Jan 22, 2008
  1. rub a dub
    rub a dub Member
    35
    Does this mske that much of a difference? I have fnally found an S3 that I like, but it doesnt have this upgrade, one of the few that I have seen for sale without it!!
    Also, is it hard to convert the centre console from single dinn to double dinn?
  2. ash_s3
    ash_s3 Active Member
    1,016
    not really, chuck a few hundred quid at it and you'll have a much better system
  3. steve1975l
    steve1975l Member
    595
    Search Andymac sup upgrade he does both non-bose & bose.
    Is it a facelift you want to convert? I am sure I mailed you a guide.
  4. bouncer--daz
    bouncer--daz A dog is for life....not just for friday nights!
    537
    I think its easier to upgrade componets etc if its non bose... I say ask Andy tho... always very helpful!
  5. 1animal1
    9,978
    i think quite a few adverts post that the cars are Bose but many i found, arent actualy Bose.....check the rear base box, easiest way to tell from what ive seen
  6. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Yes, check the sub in the boot has 2 x 4" drivers that guarantees it's Bose. The non Bose sub has 1 x 6.5" and a metal front panel (Bose is black plastic).
    It should also have a small Black amp in the righthand cubbyhole.
    Bose coming up on the HU display means nothing, you can do this via VAGCOM, it's purely cosmetic, and probably just means the previous owner had the dreaded volume problem and bought a replacement on ebay from a Bose equipped car.
    But as said already, not worth turning down a good S3 just because it doesn't have Bose, the non Bose system is easier to upgrade, so for £300 you can upgrade to a stealth sub and have a much better system than the Bose upgrade.
