BOSCH VP44 - RECOMMENDATIONS FOR OVERHAUL/REPLACMENT
The Fiend Oct 12, 2009
  1. The Fiend
    The Fiend New Member
    Hello all
    My Reliable Bosch VP44 pump has packed in. Can anyone give a recommendation for where to have it fixed repaired. Found a website for "Dieselpumprepairs.com" where they suggest that fault could just be electronics. Does anyone have any experience with them or suggest an alternative. Any help greatly appreciated and will be awarded with a pint if you stay close enough, I live near Glasgow but will happily send pump elsewhere for the best deal
  2. adamss24
    adamss24 Well-Known Member
    4,584
    405
    Try dieselbob, he is based in preston, Lancashire and he does top quality jobs ! I had replied to some of your other posts...dont listen these companies that say they can repair the ecu's, they are similar to ABS controllers and sometimes there is not much you can do to fix as they are very delicate inside. Diesel bobs fits brand new genuine Bosch controllers wich are set up on the bench (to match the flow) and the pumps are rebuilt with new cams, bearings and bushes so they are as new !
  3. fjtwelve
    fjtwelve Moderator Staff Member Moderator
    770
    10
    Just had mine done by dieselbob, jobs a good un, approx £590
