Bosch Aerotwin Retrofit Wiper Blades
nemo2182 Jul 17, 2007
  1. nemo2182
    nemo2182 Member
    130
    Hello,
    Can anyone tell me if there is a kit available for a 2000 B5 S4? I've been told that Valeo are the one's available for my car??But I've heard that these have problems with the clip system. I also need to know what size's to buy, as Standard Blades are both 21".
    Nathan
  2. S4TAN
    S4TAN Evil Incarnate
    45
    Yep - I have them on my 2000 B5 S4 ... got them from vag-parts (~£50)
  3. dsmclark40v
    dsmclark40v Member
    744
  4. nemo2182
    nemo2182 Member
    130
    But what size's do I need? is it 2 x 530mm???
  5. Rob_k
    Rob_k Member
    93
    you can get the kits off ebay for £15 ive got them on mine and they work well!
  6. dsmclark40v
    dsmclark40v Member
    744
    on the wiperblades.co.uk website you just select your car from the drop down boxes and it shows you all the blades that will fit. the drivers side is 21" (530mm) and the passengers side is 20" (500mm)
  7. nemo2182
    nemo2182 Member
    130
    I did try to select the one's for my car, but they only show normal Bosch or Valeo Flat blades. I only want the blades, not the arms as well.
  8. dsmclark40v
    dsmclark40v Member
    744
    i think they are just the blades. Mine were anyway this is the picture of them. they just clip on your existing arms
  9. Danielson
    Danielson Member
    704
    ive also got the bosch aero blades on my b5, just the blades. £25 from wiperblades.co.uk
  10. S4TAN
    45
    Yes sorry - forgot to mention that the £50 price tag from vag-parts is for blades AND arms ...
  11. Mr K
    Mr K Member
    335
    just orderd some from ebay for £15.95 deliverd. interested to see how good they are. the ones on the car suck so im certain that these will be a vast improvement!
  12. nemo2182
    nemo2182 Member
    130
    Thanks for the info lads, but a few of u look like u got the pre-facelift models. Are the Arms different, cos if u go to wiperblades.co.uk, they list them up 2 98', but not from then onwards, and mine is 2000 model???Help! I want Bosch!
  13. Nessy
    Nessy VW + Audi mad
    973
    97
    I reckon you should be OK; having been looking at www.wiperblades.co.uk myself under A4 Avant (as thinking about getting a set myself!) they list the Bosch Aerotwin retrofit as 94-01, part number AR530S?
    If you then look at A4 saloon it comes up with same Bosch part number but years upto Dec 1998?
    Its probably a glitch and reckon you'd be fine ordering the Bosch ones for your 2000..................
  14. nemo2182
    nemo2182 Member
    130
    Lets go 4it then! 21" + 20" yer? thanks 4all help guys
  15. 4Ring Jelly
    4Ring Jelly Member
    41
    anyone have the Valeo Ultimate wiper blades?
    and what is the "problem" with the clip, that the OP posted about?
  16. Nessy
    Nessy VW + Audi mad
    973
    97
    Well, I ordered a set of the Bosch Aerotwin retrofit blades online from www.wiperblades.co.uk on Tuesday night and they arrived this morning!
    Fitting was a doddle and they look a lot better than the old conventional blades which were up for renewal anyway......
    The only fly in the ointment is that there doesn't seem (yet) to be an Aerotwin retrofit blade for the rear wiper on the Avant, so it looks like us Avant owners would have to buy a later style Aero wiper arm and blade if we really wanted to go down that route at the rear...........
    Think will see how the new wipers perform before I go rushing to replace the current rear set-up though............
  17. Speedy
    Speedy Member
    85
    I got a set of Bosch Aero ones from wiperblades.co.uk but the passenger side isn't curved like the OEM's so doesn't contact properly - has no-one else found this or am I missing something?
  18. Nessy
    Nessy VW + Audi mad
    973
    97
    The Bosch 'normal' blades I took off were indeed curved on the passenger side; the blurb on the Bosch website reckons that the retrofit blades are designed to match the windscreen profile of each vehicle in the retrofit range (which isn't that big at the moment...).
    To be honest I haven't found the lack of a curved blade a problem, I did a 400 mile round trip yesterday and encountered a few periods of torrential rain and the Aerotwin wipers were superb, a lot better than conventional blades for sure......
  19. A4NA18
    A4NA18 Member
    138
    If I may input my experience, I have ordered some Bosh from wiperblades.co.uk and fitted them really easily, the first instant of satisfaction gone, I have indeed noticed that the contact was not proper on the passenger side and now it leaves a mess on the far left side when the windshield is dusty. I also have and impression that even on the driver side the left end bit doesn't contact the windshield properly: whenever it passes, it jerks off some big water drops on the passenger side after the wipe.
    TBH, the result is ok but how could we change (the arms maybe ?!) to have the blades contacting the windshield properly? Is there a way to have some "real" aeroblade "arms" made especially for them?
    Thank for the advice.
    Cheers.
  20. jazzyc
    jazzyc Member
    153
    i contacted the website above and they said they do not do the Bosh blades only the valeo ones?
    2000 facelift 1.8T
  21. Speedy
    Speedy Member
    85
    That's where mine came from, maybe they stopped selling them... The drivers side was fine but the passenger side fouled the plastic underneath the windscreen (unless I took the arm off and moved it up one spline). Either way the fit was not that good so I didn't use them. Not good to list them for a particular vehicle when they are just a generic size not model specific.
  22. Mr K
    Mr K Member
    335
    got the cheapy ones from ebay thought; they are alot better than the old ones but the drivers one flutters at the tip leaving lines of water on the screen near on the middle 3rd of the swipe. i swapped them over and it was exactly the same with the other blade, and the ones i took off do it too; i assume it is down to the design of the screen or i have somthing on there? do all A4 b5s do this?
  23. Nessy
    Nessy VW + Audi mad
    973
    97
    Have to admit that the recent postings on this thread have got me stumped!
    Are we all talking about the same products here? :confused:
    My blades came from wiperblades.co.uk , were delivered last week and are the Bosch Retrofit 'Aerotwin' which fit onto the old-style arms.
    Fit is perfect and so is their performance?
    Would be most interested to hear if you are indeed having difficulties with the same type as me as I've been raving about my new wipers recently to everybody who will listen.........:sm4:
  24. Speedy
    Speedy Member
    85
    I don't understand then, my passenger side Bosch is definatley not a good fit due to lack of curvature, unless Bosch have changed them OR you are using a different part number. Mine were Bosch AR530S. Maybe I need a different part number.
  25. Nessy
    Nessy VW + Audi mad
    973
    97
    Mmmm, curiouser and curiouser! Mine are AR530S too!
    When you say lack of curvature is a problem, just how much does the passenger side blade not sit correctly?On mine the last 1 inch (ie the tip) of the passenger side blade sits about 3mm proud of the screen, but once the wiper starts wiping its arc towards the drivers side it soon touches the screen?
    One last thing as a thought, does the box your AR530S blades come in say 'for right hand drive' as mine does?
  26. Turbo Lag FTW
    Turbo Lag FTW Hate those none insured you know who types
    235
    Hmmmm I have got bosch blades on at the moment, and imo the champion blades I had on previous were a better blade. But I`ll stick with the bosch ones for the time being as I dont wanna spend anymore cash on the car this month.
  27. A4NA18
    A4NA18 Member
    138
    Soon I'll post a picture or a video even. GRUNT GRUNT.
  28. tracer
    tracer '96 a4 1.8 se
    266
    give the guys a call and talk it through with them. they are very helpful. i ordered the valeo ones originally and wasn't happy with the fit of them as the locking mechanism kept opening on its own. they swapped out no probs for a set of bosch ones, which fit perfectly.
  29. Speedy
    Speedy Member
    85
    I did, they were happy for me to send them back, just didn't get round to it... I have no problem at all with wiperblades.co.uk!
  30. Speedy
    Speedy Member
    85
    I will check this...
  31. jcb
    jcb Active Member
    4,132
    13
    you can get a rear Aero blade for the B5 Avant - it is just made for a 8E car(think that is the B6 chassis). I got one from a guy on German eBay.
    I got OEM aero wipers for a B6 and had some brass adapters made to fit the spindle, they work OK but stick up a little. Got them cheap so it is a temp measure
    looking at VAG parts for new arms for the front now
