Bora S3 - Reverse Light Switch
Yohan87 Nov 6, 2011
  1. Yohan87
    Yohan87 Member
    426
    12
    Hello,
    I have a VW Bora 4motion with an Audi S3 AMK engine/gearbox fitted.
    Neither of my reverse lights are working and the bulbs are fine, just checked them yesterday.
    I suspect this is the common gearbox switch issue and would like to order a replacement.
    The only thing is, I'm unsure of the type I need, I was told the engine in the car came from a 2002 AMK S3 but that's all I know.
    Looking at ETKA there seems to be a couple of versions of this switch - 02k 945 415 (transmission case magnesium), and 02k 945 415 G (transmission case aluminium).
    Then there are also a couple of versions on EuroCarParts.
    Unfortunately I can't phone Audi/VW because the car is a mix mash of parts :)
    Thanks in advance.
  2. Yohan87
    Yohan87 Member
    426
    12
  3. Yohan87
    Yohan87 Member
    426
    12
    Bump for the lunchtime surfers :)
  4. Paradox1
    Paradox1 Active Member
    1,833
    88
    Bora with a s3 engine, hmmm now where have i seen that before....:)
    Sorry cant help though, I havent changed to a s3 engine yet
  5. Westy
    Westy Well-Known Member
    17,440
    1,097
    IF you tell the VW/Audi parts man that you have an S3 then they should be able to get you a parts number.
    By the way, any pics of your bora?
  6. Yohan87
    Yohan87 Member
    426
    12
    Audi just said it's either of those part numbers but he doesn't ever remember seeing a magnesium one so I'll just go for the Alu one.
    On another note, injector seal prices are nuts! £4 for a single o-ring!?
    Will get pics sorted later on Westy.
  7. aragorn
    17,889
    689
    have you checked the fuse and bridged the wires at the switch to confirm its actually faulty?
  8. Yohan87
    Yohan87 Member
    426
    12
    You know what, I haven't actually...
    I just always assume the worst now. I'll give that a check tonight.
    Don't suppose you know what fuse number it is off the top of your head?
  9. SiGainey
    SiGainey Member
    505
    9
    I do injector seals for the AMK engine for £1.50 for 8 of them if you're interested....
  10. Westy
    17,440
    1,097
    I assume the seals for the BAM are the same Si?
  11. SiGainey
    SiGainey Member
    505
    9
    Yes mate, I would think so...
  12. Yohan87
    Yohan87 Member
    426
    12
    Yeah I'll take you up on that, PM me the details and can pay you tonight.
    P/N is 035 906 149 A, ETKA says they are the same.
