Boot Rattle When Bass High
Scott_Hol Jun 16, 2011
  1. Scott_Hol
    Scott_Hol Member
    584
    As above, i like to play my music loud and with lots of BASS but havnt been recently because when i do the left side of the boot is rattling, when the music is going you can feel where the speaker is and clearly where the rattle is coming from, actually when you hold the area down abit it does not rattle.
    question is does anyone have any suggestions to cure this.
  2. J8TT X
    J8TT X Member
    360
    9
    Do you have BOSE?
    I have the same problem...
  3. Scott_Hol
    Scott_Hol Member
    584
    Yes m8 BOSE FTW:thumbsup: but its poorly atm :(
  4. Farhan
    Farhan Active Member
    1,234
    57
    Dynamat!
  5. Scott_Hol
    Scott_Hol Member
    584
  6. Scott_Hol
    Scott_Hol Member
    584
    Hmmmmm sound deadening, dont really want to make it any quieter, are you sure this is what i need?
  7. Scott_Hol
    Scott_Hol Member
    584
  8. Ash187
    7,437
    699
    is it the boot lid that is rattling or something in the panel where the Bose sub is?
  9. Broken Byzan
    13,229
    464
    sound deadener doesn't make it quieter it helps absorb the sound vibrations and keep the sound inside the car where you need it.
  10. Farhan
    1,234
    57
    Sound deadener can help reduce the rattle a bit if you apply it to the panel it will add a bit of mass to it, stopping it from rattling. There are other methods as well like acoustic foam panels which if put in place may eliminate the plastic rattle sound against something.
  11. Scott_Hol
    Scott_Hol Member
    584
    Is not the shelf or the lid its the panel that sits infront of the sub. . .
  12. Scott_Hol
    Scott_Hol Member
    584
    can any1 post pics ov how to get panel off?? also link of good sound deadening
  13. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,216
    303
    get some soundproofin in there matey ive got the same prob (no bose) and i put a bit in there hey presto no more noise just good sounds
  14. Cheese
    Cheese Member
    182
    Before you go blaming the BOSE or buy soundproofing open up the boot whilst the bass is thumpin' - I had the same problem and it turned out to be a loose 1/2" screwcap cover in the plastic around the boot interior. If it is the same issue you are seeing, pop it out, stick a little foam in and pop the cap back on.
  15. Scott_Hol
    Scott_Hol Member
    584
    Its not the cap
  16. FranA3
    7,216
    303
    mine was doing exactly the same as yours scott bit of soundproofing job done
  17. Kash3838
    Kash3838 Member
    185
    19
    get a roll of stinger or dynamat...don't use the cheap **** as you will have to double or triple lay it down to get the same effect, thus adding anymore unwanted extra weight to the car. that should sort it out! i'm gonna do my doors and boot. not upgrading the bose. but it will keep the sound tight and stop any unwanted rattles.
  18. pazaz
    pazaz Member
    323
    On my previous S3 the bose sub grill cover was loose. I tightened this up with a torx bit and it resolved the problem.
    May be worth a look?
  19. Scott_Hol
    Scott_Hol Member
    584
    Definately needs soundproofing can any1 post up some decent stuff to use need enough to cover the left side panel of boot
  20. Scott_Hol
    Scott_Hol Member
    584
    Its not the screw m8 enverything is tight its the actualy panel itself. cheers tho
  21. FranA3
    7,216
    303
    ive got a weird rattle now all of a sudden when ive got the window down with the music up something is rattling in the door if i put the window up a touch it stops weird might have to crack out the soundproofing again i think lol
  22. Scott_Hol
    Scott_Hol Member
    584
    Fran get searching and get me link lerd i would be ever so grateful haha:friends:
  23. FranA3
    7,216
    303
    im guessing you have the same rattle then eh lol
  24. Scott_Hol
    Scott_Hol Member
    584
    Nar just the 1 above but will be using the same soundproofing
  25. FranA3
    7,216
    303
    ah right i get ya due
  26. Kash3838
    Kash3838 Member
    185
    19
  27. Scott_Hol
    Scott_Hol Member
    584
  28. Kash3838
    Kash3838 Member
    185
    19
    its was a big audio install 147db! hence the dynamat. but i always use dynamat weather its to isolate rattles, unwanted exhaust sound etc
    its the best sound deadning on the market!
  29. FranA3
    7,216
    303
    its also £££ to buy isnt it mate
  30. bagey
    bagey aud you do !
    198
    scott you checked the back licence plate fella ???
  31. Scott_Hol
    Scott_Hol Member
    584
    By the looks of things, £3k on soundproofing! i wouldnt dare!
    Yea its definatly what i said above just need to get round to fixing it, dont really know how to get into the side panel though without what looks like taking the whole boot apart.
    Any1 got any pointers? pics would help.
  32. FranA3
    7,216
    303
    from what i can remember remove partly the rubber / unclip the middle plastic part that holds the warning triangle / unclip the side pannel lift over luggage hook on the floor thats the basic way of it if you like i can take a few pics of it 2morow its too dark now
  33. Scott_Hol
    Scott_Hol Member
    584
    That would be spot on Fran my man:) coz i didnt understand a word you just said. . . was it in Welsh :p haha
  34. ckman85
    ckman85 Member
    91
    Reliable tissue paper, where eva its rattling from, use tissue paper to fill the gap between the rattle lol
    Thats wot i did wen i was a student and couldnt afford sound deadening AHAHAHAHA
  35. Scott_Hol
    Scott_Hol Member
    584
    Haha i think myprid and joy is worth a little more than tissue paper m8 thanks for the tip tho:thumbsup:
  36. FranA3
    7,216
    303
    must have been my welsh accent coming through soz dude lol i'll grab some pics for you now i'll even take mine apart so you can see exactly what to do
  37. FranA3
    7,216
    303
    right then here goes first remove boot mat and parcel shelf get a screw driver in the gap like this
    do that on both sides the clips are there then push it forwards a bit like this
    then lift it up
    remove rubber
    up to about here
    next remove boot light or just get it out of the hole like this
    then it should be like this (see my soundproofing)
    to put back togther do this push it into place like this
    when fitting the centre bit make sure that the bottom lugs go into these pins here in red on my car
    then push down hard when its lined up
    job done
  38. Scott_Hol
    Scott_Hol Member
    584
    M8 your too much of a ledge haha cheers for the trouble ill get it sorted and post back ;)
  39. FranA3
    7,216
    303
    not a problem dude glad to help after all these forums are all about stuff like this eh , plus if anybody else needs to know they know where to look dont they matey
  40. Scott_Hol
    Scott_Hol Member
    584
    Very true m8 hopefully i can do you a favour soon its 2-0 now haha. . . . . . P.S you have REALLY hairy arms :lmfao: still the main man tho:friends:
