BOOT PROBLEMS (WONT OPEN FROM KEY OR DRIVERS DOOR)
jakeA42T Jul 24, 2012
  1. jakeA42T
    jakeA42T Member
    90
    Not sure what happened maybe someone messed it up but now the boot wont open from the drivers door switch or the key, not hat bothered but it's a pain in the backside trying to open the boot with a key.
  2. Richardesty
    Richardesty loves quattro
    742
    20
    Sounds like you've lost power to the boot solenoid.
    When mine did this, after a couple of days or so I'd lost all lighting relating to the boot - ie numberplates, rear fogs etc.
    It's a common fault ironically caused by opening and closing your boot.
    There's a bank of wires that sit within a plastic protection tube which is strapped to the left hand hinge. Wires within here fray over time and eventually break.
    You need to strip the protective covering off, locate the broken wire and reconnect it.
    In my case it was the earth wire and I lost the lot.
  3. hades-
    9,481
    646
    as above i had the same
    thick brown wire was my problem.
  4. jakeA42T
    jakeA42T Member
    90
    It just failed it's MOT for no REG or fog light so it seems to be the same problem, cheers.
  5. Richardesty
    742
    20
    You'll be hunting down the thick brown cable in that case...
  6. jakeA42T
    jakeA42T Member
    90
    Quick update, found the broken earth under the left hinge in the side wall of the boot, replaced broken section, heat shrinked, job done.
    :thumbsup:Thanks for the help everyone!
  7. Richardesty
    742
    20
    Nice one Jake, pleased you're sorted :racer:
  8. Dani_B19
    9,167
    362
    So looks like mine will the earth after stumbling across this.
  9. carlcall
    carlcall Well-Known Member VCDS Map User Team Brilliant Black Audi A4 Audi Avant Owner Group TDi Manual
    1,915
    880
    Come on Dani get it sorted out!
  10. Dani_B19
    9,167
    362
    Look I'm off Thursday so weather permitting I'm on it Carl.
    carlcall likes this.
  11. ryno1
    ryno1 New Member
    Is it set to valet mode? I had this recently, put key in and turn it to a different position (forget which) and it's all perfect again
