Boot only opening with key
AudidriverA4 Oct 5, 2012
  1. AudidriverA4
    AudidriverA4 Member
    183
    Hi again
    Ever since I bought my A4 the boot has only ever opened with the key,
    Every time I press the boot open button on the key nothing happens no sound of solenoid or anything,
    Even when the car is unlocked, I still have to open the boot with the key, which is very annoying
    Any one have an idea what could be causing this problem ??
  2. Andi25th
    Andi25th Member
    227
    17
    The boot lock needs to be in a certain position for it to unlock or open via the Fob.
  3. kite
    kite Member VCDS Map User
    677
    Depending on the position of the key slot the boot lock can be isolated from the central locking.
    Put the slot in the vertical and try, then out it horizontal and try again.
    You could also have a broken lock actuator
  4. hades-
    9,481
    646
    and you need to press the remote button for a few seconds.
  5. AudidriverA4
    AudidriverA4 Member
    183
    I tried all methods and it's still no good there :sorry:
    Where is the lock actuator located are they easy to replace?
  6. hades-
    9,481
    646
    take the trim off and its up there with the lock
    quite easy to change
  7. AudidriverA4
    AudidriverA4 Member
    183
    Cheers I'll give it a go anyway,
    Is it better going to Audi themselves for a genuine part or would an ebay one be as good of quality?
  8. hades-
    9,481
    646
    id go second hand from a scrappy or ebay
    i can see audi charging loads
    or it could just be a wire off
    or check the wires from boot to car they can and do snap worth a check.
  9. boomtown
    boomtown Member
    130
    part is £18 from main dealer, ill find part no in a bit
  10. boomtown
    boomtown Member
    130
    8E5 962 115
  11. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    I would check the wiring to the boot before you spend money it costs nothing to check and they do break mine did it about a year or two ago
    iantype-r likes this.
  12. AudidriverA4
    AudidriverA4 Member
    183
    Is that the wiring behind the trim on the Boot lid? (Mine is a saloon model by the way)
  13. stu_m
    1,440
    it usually breaks where it runs up the left hand side hinge on the boot lid
  14. AudidriverA4
    AudidriverA4 Member
    183
    Cheers again Stu
    I must owe you a few points at this stage :beerchug:
    If the wires are okay I think I'll try the lock actuator then
  15. stu_m
    1,440
    No worries
    it is a bit of a pain to get to the wires thought i had to pull the grommets out and the wire through to give some slack
    if you have a multimeter you could always check your getting power to the actuator when you press the key fob
  16. AudidriverA4
    AudidriverA4 Member
    183
    The multimeter is out of action at the moment, need to order new leads for it,
    I have a circuit tester though, It should do the job shouldn't it,
    Once the button is pressed if I have the circuit tester hooked up to it, once I press the button the tester should light up if it's getting power right?
  17. stu_m
    1,440
    A circuit tester might work but it will just be a quick flash of power
    you can only try
  18. StuG808
    StuG808 1.9tdi130 Avant FailWheelDrive
    257
    9
    I posted this in a big thread about this issue. I had exactly the same issue and fixed it. I posted this
  19. AudidriverA4
    AudidriverA4 Member
    183
    Thanks StuG that sounds brilliant
    Do you have a link by any chance to your tread??
  20. StuG808
    257
    9
  21. AudidriverA4
    AudidriverA4 Member
    183
    Took off my actuator today
    Took me a few seconds to locate it :laugh:
    I then used the circuit tester to test the plug going into the actuator when I had it removed, Lucky enough the actuator is getting power, so it has to be the actuator itself that is at fault,
    Here is the old one it looks very dirty
    All I need to do now is order a new actuator :cool:
  22. Jules
    Jules Member
    130
    Keep us updated got the same problem with mine just not been in an ordered a new one yet
  23. AudidriverA4
    AudidriverA4 Member
    183
    Will do, just rang the main dealers and I'll have to collect the part myself, just don't know when I'll get time off work now to collect it :(
  24. AudidriverA4
    AudidriverA4 Member
    183
    Just after fitting a new boot actuator this evening.
    Made absolutely no difference at all :aggressive:
    Any other ideas anyone
    there is still no noise to be heard at all from the new part and it is getting power :uhm:
  25. troopa
    troopa Member
    159
    I know that if you lock the doors from inside the car with the key button by the drivers handle and then 're open with that button. This doesn't open the boot and you get no response at all from the boot soft button. Maybe you have some fault with that door lock??
  26. AudidriverA4
    AudidriverA4 Member
    183
    Just noticed for the week the actuator was removed from my car, the bulb gone light came up on the dash, both of my number plate bulbs went,
    But when I fitted the new actuator, the light on the dash went out and the number plate lights are working again but sadly the boot is still only opening with the key.....
  27. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,202
    160
    Check how your key lock is turned. You can disable opening by button by putting the key in at a certain angle.
  28. AudidriverA4
    AudidriverA4 Member
    183
    Tried it everway
    Think I must have a wiring problem
  29. stu_m
    1,440
    Did you not check the wiring like I mentioned?
  30. hades-
    9,481
    646
    its got to be wireing
    as post 8
    1st thing to check on an audi
    they break in the doors boot everywhere.
  31. AudidriverA4
    AudidriverA4 Member
    183
    Hi Stu
    No I never did, when I tested the plug that goes into the actutator and there was power going into it, I was sure it was the actutor its self that was at fault so I never did,
    It looks like it could possible a fault with the earth wire now I'm thinking if thinking if the 'live' wire is bringing power to it
  32. AudidriverA4
    AudidriverA4 Member
    183
    Cheers bez101
    I'll take a look at it tomorrow
    Nearly getting sick now of taking the trim on and off on the boot now :laugh:
  33. hades-
    9,481
    646
    on the saloon left hand side as your looking at it
    the hinge take the plastic cover off just clips on
    undo the tape on the wires its normaly the thick brown but could be the thin ones
    have a very good look as they sometimes dont look damaged
    did it on my B7 took my fogs and 1 numberplate light out and lock.
  34. AudidriverA4
    AudidriverA4 Member
    183
    If I remember it looks like there isn't to much space to work with there :laugh:
    So it's wire will more than likely be broken ?
    twist the ends together, insulating tape and job done hopefully
  35. hades-
    9,481
    646
    very tight add some wire
    sometimes there broke on the inside if the plastic and they look ok
    give them a good pull.
  36. AudidriverA4
    AudidriverA4 Member
    183
    Thanks again bez
    I'll give it a try tomorrow
    Looks like it's going to be a tricky enough job
  37. AudidriverA4
    AudidriverA4 Member
    183
    Had a look at the wiring today:
    The only wire that looked to be damaged was a slightly thicker brown wire, compared to the other wires:
    It doesn't look to me that the wire was that badly damaged to cause the actuator to fail :confused:
    But do you guys think?
    Think I might have to give up on the idea of my boot ever opening with the button on the key :blush:
  38. stu_m
    1,440
    you have to open the full loom up as mine was further down and a right pain to see!
  39. stu_m
    1,440
    oh and mine was on the main body side too
  40. AudidriverA4
    AudidriverA4 Member
    183
    Cheers stu
    will try and take off all that plastic around the wires if I can
