Boot not closing HELP
CaTFiSH Jul 24, 2007
  1. CaTFiSH
    CaTFiSH Member
    66
    Hello,
    (Facelift model boot lock is electronic, it doesn't work with airflow as pre-restyling does).
    Days ago I discovered that my boot wasn't closing. The pump works with the doors and makes noise, however the boots doesn't close and the pump continues working for a few more seconds. I changed the microswitch on the boot lock, but the problem is still there. There are not washer liquid leaks and VAGCOM only says that the pump working time have been exceded.
    The boot doesn't close with the remote on the key, also it doesn't close from the inside with the switch on the driver door, however it closes with this switch when the ignition is turned on.
    Meanwhile i'm closing it with the mechanical system.
    Please I need more ideas before changing the pump.
    Thank you.
  2. CaTFiSH
    CaTFiSH Member
    66
    Is only closes with the car started, but it doesn't close the boot without the key or with the key without starting the car :(
    Please help :(
