Boot Locking Problems
_a3sport Aug 1, 2012
  1. _a3sport
    _a3sport Member
    138
    I have problems with the boot lock, I'm not convinced its the soft touch mircoswitch so thought I'd ask on here first. To summarise my problem:
    1. If the car is locked and I double unlock on the keyfob and then push the soft touch mircoswitch to open boot it opens no problems.
    2. If the car is unlocked and I push the boot unlock button on the keyfob (the light on the keyfob flashes) I hear nothing and pushing the soft touch mircoswitch does nothing.
    3. So basically if I want to unlock the boot when the car is already unlocked sometimes a double unlock/soft touch mircoswitch works other times I need to lock then double unlock/soft touch mircoswitch and generally faff around like an idiot until it finally decides to work.
    To me it seems like some sort of control system issue since it always unlocks when the car has been locked for a period of time. Also I should add I've only had the car 6 months I found out after purchase the boot was busted.
    There is no water damage from window washer.
    Any ideas?
  2. mike foster
    3,967
    What is a 'soft-touch microswitch' ???
  3. _a3sport
    _a3sport Member
    138
    The bit you push with your fingers to open the boot, above the number plate. Seen someone call it that in another thread. Not sure what else to call it!
  4. mike foster
    3,967
    If the car is unlocked then don't press the remote, just use the 'soft touch'. If the car is locked then you have to press and hold the middle button to open.
  5. _a3sport
    _a3sport Member
    138
    Cheers got it now, the instruction manual says press the boot unlock button, not hold. Never had boot unlock on keyfob before.
