Boot leaking water
doublem_1 Apr 13, 2012
  1. doublem_1
    doublem_1 Member
    500
    Over the past few months I have noticed the occasional few drops of water in my boot. I looked in to more today and noticed it's coming in at the top of the boot on the drivers side and dripping the gap in the grey plastic interior trim. Has anyone else had this problem?
  2. actualeddie
    actualeddie Member
    211
    Rear Washer, pipes probably blown off, two screws under handle and pop off the plastic, POP HARD its tough to get off
  3. actualeddie
    actualeddie Member
    211
  4. doublem_1
    doublem_1 Member
    500
    But it only comes through when it rains, I don't use the rear wiper/wash. I will check it anyway though. Thanks.
  5. actualeddie
    actualeddie Member
    211
    maybe one of the seals has gone, tip a bucket of water over and see where it comes in from with the plastic off.
  6. Greig300
    Greig300 Member
    257
    Defo rear washer. Was on mine.
  7. jay1601
    jay1601 Well-Known Member
    1,347
    73
    have you got a sun roof ?
    if so more then likely you got a blocked drain pipe and its over flowing into the boot. seen it happen on a few golfs.
  8. doublem_1
    doublem_1 Member
    500
    Nope no sun roof. Is the panel easy to take off? Its the one right at the rear of the roof interior.
  9. actualeddie
    actualeddie Member
    211
    wonder if its leaking through the aerial, is it about that area?
  10. doublem_1
    doublem_1 Member
    500
    Well the water always drips through right hand side of the panel. I would of though the headlining would wet if it came through the aerial. I will check it out though.
  11. doublem_1
    doublem_1 Member
    500
    I have traced this to the aerial. Despite 18 months ago replacing the rubber seal. Have ordered some sikaflex so that should sort it. Or should I of bought a replacement rubber seal? I tightened the nut as much as I dared and it still comes in and runs down the cable.
  12. Dani_B19
    9,382
    403
    You ever fix this mate?
