Zonda_
I can't get the boot open on my 97 A3, it opened fine yesterday and I've never had a problem, I can here the lock opening and closing but it won't release.
Help!
Help!
There are just two philips head screws that im pretty sure you can still get at from inside the car with the boot shut. (they are at the bottom left as you look inside the car) After you've undone those, the trim is just held on by plugs (in a 4 x 2 grid form the lower and around the outside on the upper trim) which just require force to pull off.It certainly doesn't seem to be, I spent an hour in the boot yesterday, I've undone every hex bolt I can see but as you say, the plastic trim panels are still being held in place by things that you can't see until the boot it open. I'm at a loss, it looks like a big garage bill to get it sorted.
It moves easy enough with a screw driver, I can see the linkage moving when I operate the paddles on the outside. No matter how hard I shut the boot it won't latch but moves perfectly freely otherwise.
